You should find a large button or flap on the floor tool. This is usually spring loaded and needs to be OUT. This should then let air in to drive the turbine which drives the spinner.
Check out Vacuum Cleaners Upright Hand Stick Canister Vacuums Dirt Devil
Hi Donna! Attaching the bare floor tool is quite easy. Hold the bare floor tool in your hands with the squeegee blade closest to you. Then hook the front of the bare floor tool onto the clear lip at the floor level and swing the tool underneath your machine until it snaps.
The brushes can be turned off on most of them via a switch on the hood. There shouldn't be water coming out onto the floor unless you are pulling the trigger at that top. You probably broke this when attempting to use the tools.
The Hero 1600 should use 32mm type floor fittings which means on EBay you can pick up just about any type of floor tool which is suitable for most Hoover, Electrolux and Morphy Richards/Goblin appliances. This means you can use other branded tools and floor heads just by their fitment rather than the name.
EBay is a lot cheaper than having to order a brand new one from Hoover themselves. Alternatively try any floorcare repair shops who offer additional tools which can be purchased. 9 times out of 10 they will have a floor head which is similar to the one which has broken on yours.
Usually when the hand tool works ok, then the heater inside the handle asm. is clogged. The water bypasses the heater when you use the hand tool. Other then that it could be a bad pump.
