Question about Garland H283 Gas Kitchen Range
I have a used kenmore propane gas stove that i just bought from someone. We have hooked it up but can only get the oven to come on. The stove top burners will not come on. We we turn on the burners we do hear it clicking, but we can't get it to ignite- can you PLEASE help?
  • 585 Answers
In the old days stoves were lit with a match. If this does not work for you it would be due to the stove's lines remaining "airlogged" after the move. The oven purged and ignited more easily because it has a much larger orifice, so the air bled more quickly. I expect if you were to leave one burner turned on long enough for the air to bleed out you will find it to ignite normally. Do not leave the stove to bleed unattended, and if you encounter a strong smell of the gas, turn off the burner, and ventilate the room as needed. The smell of gas would indicate that gas is present, it may be possible that a lead came disconnected from the ignition module in the back of the stove. Again if this is the case, the ol' match will light the burner. Be Careful!
Posted on Dec 14, 2008
The wall behind my propane oven is black, why?
possibly the air shutters were not adjusted when new for propane use,most units come set-up to burl natural gas but need conversion to burn l.p. gas by changing the orfices on the top burners,then turning the orfice spuds down on the bake and broil orfices as to control the flow of a heavier gas and also opening the air shutters on these venturi gas feed tubes next to these orfices
Dec 12, 2012 | Kenmore Ovens
I have a kenmore gas stove 790-75711890. my oven ignitor was only glowing. so i thought not enough gas i removed pressure regulator and blow thur it then reassemble. still not liting. i bought new oven...
On the top of pressure regulater is a removalable piece that fits one way for nautral gas and the other way for propane i am wondering it was installed upside down afer ya reassambled it, accidenttly setting it to propane which defeintly will cause that
Aug 22, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a K/A kgst307 gas stove that was bought new as a natural gas unit. After 3 years, I moved to a house that had propane. NO PROBLEM because an LP conversions kit came with the stove. Used the stove on...
Although the natural gas orifices for the stove top burners were replaceable with propane orifices, many ovens/broilers orifices are simply adjustable using a 1/2" open end wrench to convert from one gas to another. Some brands are adjustable and some have to be changed out. It depends on the make and model. Do you have your owner's manual? It contains detailed info on converting your unit. I included a link below to choose from the list to download your manual. You'll need your exact model # listed on your stove. Pull out the bottom drawer and look at the data plate for the model # and then find it on the list for the correct manual. Douglas
Oct 01, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kenmore propane stove (16 yrs old). Oven quit working yesterday
is ther a slight propane smell around the stove?i'm thinking your oven pilot light got blown out
Jan 31, 2010 | Kitchen Ranges
How do you start the oven on a Hardwick propane range?
The bottom part of the stove in the front has a drawer you pull out which has a broiler tray located there. You should be able to fold the door down and use a flash light to look inside . You will find a pilot light set-up there.
The stove I have has the pilot gas on all the time, so as soon as you turn on the gas to the range, the pilot gas is open to atmosphere.
I just light a match and reach in to where the gas piping can be seen and the pilot flame will light.
There is only a small amount of gas coming from the pilot orifice, so there isn't any danger lighting it when the gas is first turned on at the tank.
In fact you may have to wait a few minutes for it to light at first because the propane line maybe full of air. I usually light the top burners of the stove first and by that time the pilot gas for the oven is ok to light.
Jan 05, 2010 | Kitchen Ranges
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Propane coversion of kenmore 790 gas range
Most gas stoves are shipped for natural gas .You need to check the orifice on each burner to see if they are for natural gas or propane.If you ordered propane the stove should have been shipped with the orifices.They may be in a bag with your stove documents.
Jul 13, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven burner pulsates
The gas regulator valve would also be my first guess. It seems to not be allowing enough gas into the system. When the top is on, only a small amount of fuel is required, and when properly mixed with the air all is well, but when you also put on the oven, the regulator won't allow enough gas into the system, so it's "burning lean". I'd get it fixed before it pulsates so bad that it actually blows out the flames and you're left with a propane smelling dangerous house.
Apr 06, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore gas: SMELLS
turn them on see if the flames are orange or blue then reply open the door and look from the side through the little slots in the bottom of the oven to see also is there soot and are you on natural gas or propane your reply will come to my e mail
Nov 09, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Apr 08, 2007 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Garland H283 Gas Kitchen Range Logo
300 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
