Question about Canon PIXMA iP1800 InkJet Photo Printer
I have just purchased ink cartridge 830 black for canon ip 1800 but the lights are blinking orange please tell me why this is happening
    Problem Solver:
  • 6 Answers
I received this response from canon.com. Hope it helps you.
If the paper feed rollers become dirty, they may not be able to properly
feed paper due to the feed roller's slippage. If paper does not feed
correctly, perform the following to clean the paper feed rollers:
1. Open the Printer properties.
For Windows Vista
a. Click / Select 'Start' from the bottom left of the Windows screen,
'Control Panel', 'Hardware and Sound', and then click on 'Printers'.
Note: If you are in 'Classic' view, Click 'Printers' directly from the
'Control Panel'.
b. Click your right mouse button on the listing for your printer, and
then select 'Preferences' from the menu that appears.
For Windows XP Home Edition
'Control Panel,' 'Printers and Other Hardware,' and 'Printers and
Faxes.'
For Windows XP Professional Edition
a. Click 'Start' from the bottom left of the Windows screen, and
'Printers and Faxes.'
For Windows 2000
and 'Settings,' then 'Printers.'
then select 'Properties' from the menu that appears.
2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
3. Remove all sheets of paper from the auto sheet feeder.
4. Confirm the following message, and click 'OK'.
Note: Clicking 'OK' will activate the paper feed rollers 30 times. This
activation will take about 90 seconds. Do not perform other operations
until this operation has finished.
5. Confirm the following message, and click 'OK'.
6. After the continuous paper feeding operations in step 5 have
finished, load three sheets of plain paper and click 'OK'.
7. Confirm the following message, and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
8. Click 'OK'.
Roller Cleaning is completed.
If the issue continues to persist, try fanning the paper before
reseating in the automatic sheet feeder.
Follow these steps to fan the paper in the Auto Sheet Feeder(ASF):
1. Remove all documents from the ASF.
2. Check for any obstructions.
3. Fan out the sheets of paper so that they do not stick together.
4. Align the edges of the paper.
5. Insert the document stack, face up, into the ASF until you hear a
beep.
6. Adjust the document guides to the width of the document.
If fanning the paper does not help resolve the issue then the iP1800
printer will require service.
special toll-free number for email customers with
unresolved issues and speak to a technician* by dialing 1-866-261-9362,
Monday - Friday 10:00 a.m. - 10:00 p.m.
Posted on Apr 21, 2009
I have a Canon Pixma MG printer . There's orange lights at BK & CL that are blinking? What does that mean ?
means that the toner cartridges are just about out of ink and need replacing
BK=black and CL= color
Mar 15, 2016 | Canon Office Equipment & Supplies
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Display flashes e2 alarm light blinking won't print or copy
E2 mean reload the paper correctly and press Black or Color key from panel board.
Dec 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My Canon IP 1800 cannot recognized the Black ink
It sounds like the electrics on the back of the cartridge have failed, replace with a new cartridge, and away you go.
Jun 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The orange lamp always lights
depending on how many times the orange light flashes. if 4 flashes then the ink has run out. if 5 flashes then it can not recognise the ink cartridge, if 7 flashes then the ink is not installed properly.
Mar 31, 2009 | Canon PIXMA iP1800 Printer
Canon ip 1800 refilled ink says ink has run out, it's full
Here's how to reset the printer so it doesn't give you the out-of-ink message:   1)  Hold down the flashing yellow RESUME button for almost 1 minute 2) Open the cover 3) Release the cartridge(s) (#30 is black, #31 is color), and then reinstall cartridge(s).  Close cover. 4) Turn printer OFF (I had to wait and try this numerous times as green light was flashing & it wouldn't shut off.  Wait, then press OFF again. ) 5) Turn printer back ON, and cheer when it prints.
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Solution: Confirm the ink tank(s) are properly installed iP4300
Ensure that the ink tank is installed properly. Open the Top Cover, Paper Output Tray and Inner Cover, and then press on the 'PUSH' mark on the ink tank whose lamp is off until the ink tank clicks into place. Once the ink tank is installed properly its lamp will light red.
Ensure that all the orange tape has been peeled off as shown in (1). If a part of the orange tape remains as shown in (2), remove it completely.
(1) Correct (An L-shaped notch* appears on the ink tank.)
(2) Incorrect (Orange tape remains. Peel off the tape along the perforation.)
Nov 02, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA iP1800 InkJet Photo Printer Logo
218 people viewed this question
old marine
old marine
