Question about LaSpaziale S1 Vivaldi Espresso Machine
Pressure is weak.
Laspaziale espresso machine
    Problem Solver:
  • 9 Answers
I am a certified tech for laspaziale Are you thinking the pressure is low because the gauge on the front panel does not go all the way to the green ? many of them didn't right from the factory. the pressure is not adjustable and unless it is really low don't worry about it
Posted on Jan 06, 2009
Verismo 801
Sounds like a problem with the pods. Check they are manufacture recommended. When on espresso the pressure will be higher so a
"weak" pod could cause this. Unless the machine is producing too high a pressure. Check also there are no projections that could rip the pod when you close the holder.
Jan 28, 2014 | Coffee Makers & Espresso Machines
LaSpazial vivaldi S1
its broken you need to fixed it
Sep 20, 2013 | LaSpaziale S1 Vivaldi Espresso Machine
Pump won't come on, it has power to it, also the
The water from the relief valve means the boiler is very full, lets work on the water problem first then we will go to the pump.
IF the machine is not turned on does water flow out of the relief valve? ...if yes then check the manual fill to make sure it is in the off position. If no then we will need to check the level probe and or the inlet solenoid, because something is telling the machine it needs water.
For the pump is there any sound from it when you press the brew button? ....If yes then it might be blocked and you will have to remove the ring collar from the brass head, to remove pump from motor then check to see if pump head rotates, note direction on front of pump head. If no then you might have lost a fuse or there is a loose connection at the main box.
Jul 18, 2011 | LaSpaziale S1 Vivaldi Espresso Machine
I need a technical manual for a LaSpaziale Spazio-Mod.ek - any help?
This is about the extent of it:
http://www.laspazialeusa.com/catalogs/generaluseandmaintcatalog.pdf
Otherwise contact LaSpaziele and talk to Lucca the technical guy there in Stafford CT. 203-383-4373
Dec 16, 2010 | LaSpaziale S1 Vivaldi Espresso Machine
Rancilio Silvia Espresso water flows too quickly about 7 seconds
  1. check the coffe filter>> it could be teard up and leaking(check it carefuly it is hard to see sometimes)
  2. check the pressure you get from group. 7 - 9 bar pressure you should get to handle. if it is biger than check by pas valve and adjust the pressure, also check up boiler security valve(security valve for water for coffee)
Feb 09, 2009 | Rancilio Silvia Espresso Machine
Does anyone have a user's guide for the S1 Rossini?
I have a user guide for the S1 Vivaldi which is usable (except for instructions dealing with dual boiler) for the Rossini.
Feb 06, 2009 | LaSpaziale S1 Rossini Espresso Machine
Weak coffee and pale crema.
If you get weak coffee from espresso machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Jul 16, 2008 | Gaggia Titanium Espresso Machine
LaSpaziale S1 Vivaldi Espresso Machine Logo
296 people viewed this question
Top LaSpaziale Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a LaSpaziale Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
