Question about Archos AV700 Digital Media Player
Archos 700E will not power on
I have charged the battery separately, have another, identical, unit that works fine, so I am certain that the battery isn't the problem. Charge light doesn't illuminate when the AC adapter is attached. Won't respond to remote (have used it on the other one, it's transmitting). Any suggestions? Feels like a continuity issue.
  • see2xu Dec 23, 2008
    Won't respond to remote, either tethered to docking station, or direct. Have three different AC chargers, one battery-only, two wall plugs, makes no difference. I'm afraid I'm pooched.
    Genius:
  • 1,011 Answers
Sir,
check this link for more details
thanks
good luck
Posted on Dec 23, 2008
    Genius:
  • 1,061 Answers
NEED MORE INFO I THINK UNIT WILL NOT POWER ON IS THAT RIGHT??RICHARDM69
  • 275 Answers
Hi see2xu . Usually when there isn't even a charge light coming on means that the device is completely dead and need to be replaced, I would look for a warranty replacement if you still have warranty. Good luck!
Posted on Dec 14, 2008
    Master:
  • 479 Answers
Its the continuity problem i feel too.also check for any moisture accumulated dry with the hot dryer and then try if it works.
    Novelist:
  • 159 Answers
Reassemble the unit and hold the power button for 20 seconds. If that doesn't work ...
Behind the battery you may find a small hole for a master reset switch. Try using an extended paper clip and gently poke this hole.
  • Boogerhead01 Dec 14, 2008
    Any luck with the reset choices?
  • Boogerhead01 Dec 23, 2008
    Did you try the two reset instructions?
  • Archos Master
  • 13,433 Answers
Hey,
If there is no life in the unit there is most likely a fault on the mainboard, contact archos for repair or your dealer incase its under warranty.
It will need to be repaired if it doesn't work at all. no lights no noting contact your dealer.
  • 734 Answers
Might be there is a problem in the adapter cable.
I what do I do if my gorilla MP3 turns on then back off
Try charging the battery the battery might be bad
Dec 25, 2014 | Audio Players & Recorders
DAB radio will not work on 18v 3.0Ah battery but works on power lead. any suggestion please
I would open it up and look for a broken wire in the battery circuit, you could have a fuse in that circuit also.
Aug 30, 2014 | Audio Players & Recorders
Hi,Just purchased 2 antec gain Bluetooth receivers type bxr 100. Operating instructions are not included. Maybe it's just me, but i'm not succeeding in getting them to work. No lights at all when they
Make sure that the unit is fully charged by a micro USB the light on it will be red until it's fully charged put phone in search mode and press the center button until the light flashes red and blue after the phone finds it you should have an option to auto pair when it's not in use it will turn off when paired and working pressing either track button will start the music player then just play with the buttons and see what it does you can stop anything from the phone controls
Mar 18, 2014 | Antec BXR-100 Gry Audio...
I have a 1970's Panasonic Flip Clock Radio. (Model RC6530) The radio works just fine, but the flp clock stopped flipping. There is power going to the unit. I can also hear a low hum from the flip...
It looks like your problem might be an easy fix, at least. If the gear train between the motor and clock got stripped, you'd be in a bit more trouble. If the motor just isn't spinning, remove it from the side of the clock housing. There are 2 screws (or nuts) holding it in place. When you get it off, the cover for the motor will also be off. Apply some 3 in 1 oil, or perhaps just a tiny bit of penetrating oil, and give it a spin. From what I've read, it should do just fine. A lot of people use wd40, but I understand that can gum up over time.
This is a "at your own risk" type of repair, but as long as you unplug it before dismantling the radio, I think you'll be fine.
Feb 10, 2012 | Audio Players & Recorders
S9 doesn't play music
does your laptop have a2dp bluetooth profile
this profile is needed to play music
Sep 15, 2009 | Motorola Mobility S9 Headphones
Headphones wont turn on
battery is toast get a new one anything electronic if u do not upkeep the charging it will die qwik
Dec 03, 2008 | Sony Bluetooth Wireless Headphones - Black
Just one button wont work
That could be a software glitch with the Ipod not recognizing the button when in use.
Here is a clause on Motorolas website about it:
This device supports Bluetooth Advanced Audio Delivery, Audio Video Remote Control, Hands-free, and Headset profiles. In order for Bluetooth devices to communicate with one another, they must utilize the same Bluetooth profile. To determine the profiles supported by other Motorola devices, visit www.hellomoto.com/bluetooth. For other devices, contact their respective manufacturer.
Certain Bluetooth features including those listed may not be supported by all compatible Bluetooth-enabled devices, and/or the functionality of such features may be limited in certain devices, or by certain wireless carriers. Contact your wireless carrier about feature availability and functionality.
More details are listed on this link:
http://www.motorola.com/motoinfo/product/details.jsp?globalObjectId=177
Does your Ipod have the TEN Technologe NaviPlay Bluetooth Stereo adaptor?
Nov 22, 2008 | Motorola Mobility S9 Headphones
BOSe Wave Radio - Disk "not readable"
I had the same problem with the disk unreadable error and took my unit to a authorized repair dealer about 100 miles from where I live to have it fixed. It ended up costing me about $300 to have the CD unit totally replaced which is almost as much as I paid for the unit in the first place. I am like a lot of you that used the CD very little although the unit was about 3 years old. I think Bose has a problem and would like us to think it is very rare. I bought a Lifestyle surround system about 14 years ago that has a CD and have never had a problem with it so needless to say I am very disappointed in the Wave II Radio/CD system. I am fairly certain the problem will occur again, but only time will tell.
Mar 03, 2008 | Bose Wave Radio
Archos AV700 Digital Media Player Logo
76 people viewed this question
Top Archos Audio Players & Recorders Experts
Justin
Justin
Lynn Magnuson
Lynn Magnuson
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
