Question about Rheem 36" Water Heater Thermocouple Kit
Pilot light won't stay alight, when i release the knob after lighting, the flame goes out.
  • tompiper66 Dec 14, 2008
    Heater is actually RHEEM everhot 320
  • Anonymous Dec 19, 2008
    pilot light won"t stay alight,when i release the knob afier lighting, the flames(burner &pilot )goes out at the same time ,on my baxi bermuda back boiler.
    Problem Solver:
  • 7 Answers
Hello!! if you changed the thermocouple & the pilot still goes out !! could be a thermostat ( the electromagnet pilot safety ) goes bad !! make sure pilot is clean & should be sharp BLUE pilot !! not yellow & soft !! also hold down the button light the pilot use a digital volt meter set on dc milivolts a brand new thermocouple should test @ 30 milivolts+ - ! & if you have new style water htr with sealed combustion the thermocouple has a safety part of it ! change the thermocouple & make sure your vents for combustion air around the bottom of the water htr has lint & dust built up !!! kiddbrother i work for a gas company doing service !!
Posted on Dec 30, 2008
  • 306 Answers
Replace the thermocouple it is bad. You can get you at hardware store.
Posted on Dec 14, 2008
  • Ken Bledsoe Dec 17, 2008
    Did you fix your hot water heater? ken
Relight combi pilot light?
These are designed not to light once the thermocouple fails.the thermocouple has a small wire that positions in to the pilot light which checks the pilot is on and keeps the gas governed.once the temperature drops it shuts off the gas to prevent a build up of gas in a room where a pilot light has gone out.this is why you need to hold the button in on reignition to allow the thermocouple to heat up so the gas keeps open.
Try to relight by turning on the gas ....pressing down and holding the button for at least 10 seconds whilst firing the piezo to ignite flame.do not release gas button for at least 10 seconds then slowly release.if the flame on the pilot will not stay alight....then it is likely the thermo has failed.try cleaning the metal wire that is above the pilot jet.still no joy then it needs replacing.hope my comment is of help...please vote.
Feb 19, 2015 | Water Heaters
2006 water heater. Is it only run on gas. How do i turn it on.
If it is a regular gas hot water heater You need to turn the knob on the gas valve to pilot. Depress and hold the knob down. while doing that press the green button on the side of the valve . you may have to repeat that a few times. that button makes a spark to light the pilot. You need to hold the knob down for about a minute more to let the thermocouple heat up and signal the gas valve that it has a flame. release the knob . if the pilot flame stays on ,turn the knob back to the on position. If that does not work repeat if still not working give more info. Make and model of heater
Feb 03, 2015 | Water Water Heaters
Won't light nothing comes on
usually its a bad thermo couple,this the copper thing that the pilot light flame heats up. if the pilot will light but goes off when you release button its usually that. lowes and home depot sell them for about 10 dollars.
Dec 18, 2012 | Water Heaters
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
How do i reignite a worcester 24i combi boiler ?
I looked up this unit for you and found out it is a hot water system. She needs to get to the main gas valve to light the pilot. This unit has what is called a thermocouple on it that keeps the pilot on, even when the boiler shuts down. Its just a matter of lighting the pilot light. There should be a metal plate with the directions on it at the gas valve to lite it. You will have a knob, more then likely red or black in color on top of the valve. It will say on, off, and pilot. It should be in the on position now. Turn it to pilot. Have some matches with you and a flashlight if you can. You will need to look back into the burner area to where your pilot light will be. The thermocouple is a copper colored tubing that runs right back to the pilot, as it has to get hot from the pilot flame to work. To start, depending on how far back you have to reach with the match, you may need to use a piece of solid cardboard rolled up, a small piece to light it and reach in. Turn the knob to pilot. Now, push down on the knob and hold it down. This lets gas get back to the pilot, so you must keep it down and light it at the same time. Once it is lite, you have to hold it down for at least a minute. Slowly release it, very slow. The flame should then stay on. Once it is on, turn the gas knob to on. With the thermostat set to come on, it will fire up and heat the water. If the pilot will not stay lite after you hold it down for 1 minute, and keeps going out, the thermocouple will need to be replaced. It is the copper line that screws into the gas valve and goes back to the pilot. You can get them at any hardware store for around $6.00. Maybe you can help her install it. It is very simple to do. I believe the pilot just blew out and she will need to light it. Just follow what I have told you, and she will get it lite. Good Luck to you.
May 25, 2011 | Bosch Water Heaters
The pilot light goes out. When I go to re-light the pilot and turn the temp for vacation to medium the flame goes out again.
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Nov 26, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot l.ight will not stay lit
Oct 20, 2010 | Whirlpool Water Heaters
I have a GE smart water heater model GG40T6A. the pilot light will not stay lit. what can i do?
Oct 08, 2010 | General Electric GE SmartWater Household...
Lighting the pilot light
The steps involved can vary slightly depending on your furnace model and pilot valve type, so if possible try and find the instructions inside the furnace door cover or in the instruction manual. This is for a gas fired furnace, but applies to any gas-fueled appliance including water heater. Two of the most common types of pilot valve body assemblies either have a red reset button and a gas valve or no reset button and a valve knob that can be depressed. But whichever type you've got, if you have an older model furnace with a standing pilot (flame is lit all the time) then this is the basic procedure.
  • Turn you thermostat to 80 degrees or to a setting that will demand heat. Make sure the thermostat is in "Heat" mode.
  • Go to the furnace and find the pilot valve. The pilot valve body is a box shaped device into which the main gas line will run and is located near the gas burners. It will usually have a gas **** or valve knob that reads "On, "Pilot" and "Off." Locate this gas **** or knob.
  • Turn the knob or gas **** to the "Off" position and wait about 3 minutes for any residual gas to clear away.
  • Find the pilot. It's located near the gas burner tube assembly in the furnace.
  • Get your match or lighter ready. Sometimes the pilot is hard to reach. If possible, try and use a long fireplace match when you light it. If you don't have a fireplace match then a butane BBQ grill lighter works well too. If you don't have that, then you can fasten a match to the end of a stick when you light the pilot
  • If you have a pilot with a red Reset button, turn the gas valve from "Off," to "Pilot."
  • If you have a pilot with no red button, turn the knob from "Off" to "Pilot."
  • Place the lit match or ignited lighter tip at the pilot and depress and hold the button or depress the knob as appropriate. Depress the button or knob for about 30 seconds. This maintains gas flow to the pilot until the thermocouple gets hot enough to open the main gas valve.
  • Once the pilot stays lit, slowly release the button or knob and turn the gas **** or knob from the "Pilot" position to the "On" position. This will ignite the burners and keep the flow of gas supplied as required for the burners as called for by the thermostat.
  • If the burners fail to ignite then it may be because the thermocouple did not get hot enough to open the gas valve. Wait a few minutes and then repeat the above procedure. This time hold the red reset button or depress the knob for about 45-60 seconds.
  • Once the main furnace burners ignite, adjust the thermostat to the desired setting.
  • If you've followed the previous steps on lighting the pilot and it still does not light after, or will not stay lit, then you probably have a problem with the thermocouple or an adjustment needs to be made to the pilot. You'll need a furnace service technician to replace or repair these parts. You may find that the pilot lights, but it is an anemic looking flame. That's a different problem we'll look at in the next section.
  • If the pilot lights but the flame is a weak yellow flame, it will not get hot enough to heat the thermocouple to its set point allowing the gas valve to open.
    A natural gas flame should be a bright blue with the tip of the flame having just a tinge of yellow. A propane flame should have a bluish green flame with a tinge of yellow at the tip. The flame should be strong enough to hit the thermocouple tip about 1/2 inch from the tip end. If the flame is weak or shaky looking, check to see that a breeze or draft is not blowing on it. Adjusting the Flame
    There is usually a small screw on the pilot valve body that will adjust the flame. You may have to refer to the manufacturer's instructions to find the screw. Turn the screw as needed to adjust the flame throw. Yellow Flame
    A yellow flame is caused by lack of air and incomplete combustion. It can be caused by a dirty pilot tube tip. Split Flame
    This is caused by dirt in the pilot tube. Take a needle or small nail and gently clean the tube. Flickering or Wavering Flame
    A flame that flickers is usually caused by a draft.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 18, 2009 | Water Heaters
Rheem 36" Water Heater Thermocouple Kit Logo
2,646 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
