Question about Kenwood VR-715 Receiver
Can I connect a powered sub woofer to my VR-715
It originally had a plain one that was destroyed in a flood and it seems they are not replaceable. Are all stand alone sub woofers powered,and if I can connect a powered sub what size and how does it hook up.Or can you tell me where to find one similar to an original.
  • dgolden7 Dec 15, 2008
    I just need to know if there is any where to buy a repalcement sub woofer that just connects to the receiver. (not the electrical plug in type) Or is there an electrical plug in type that is compatable with the VR-715
5 Suggested Answers
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
connect to same terminals as front speakers, this will also cause reduced volume from front speakers. (as per owners manual)
Posted on Nov 19, 2007
  • 18 Answers
SOURCE: connecting 2 sub woofers to denon 1506 receiver
Most receivers only handle one sub at a time. If you are deadset on connecting two, you might want to consider how much power your receiver will give to each if you split the signal then determine the power of each sub. If the subs aren't the same you can be sure they will sound strange.
If they are identical and your receiver has enough power to handle them both, examine the connection the subs use to connect to the receiver and split the connection by buying a splitter at a local radioshack.
You will probably be better off using the better of the two subs instead of having both connected. Your sound quality will be more balanced and clear when it comes to bass.
Posted on Mar 03, 2009
dunnbiker
  • 8546 Answers
SOURCE: Sub woofer output port does not seem to work on my
Is the 407 set up to drive the unknown sub. It's not just plug n play.
The manual will guide you, around page 15. Also refer to your subwoofer manual. Try retrevo.com for that one.
http://www.retrevo.com/support/Kenwood-VR-407-Receivers-manual/id/480ag200/t/2/
Posted on Dec 29, 2010
dunnbiker
  • 8546 Answers
SOURCE: I can't get my sub woofer to receive a signal from
Yes. It's in the manual.
http://www.retrevo.com/support/Kenwood-KR-V990D-Receivers-manual/id/479ci955/t/2/
Posted on Aug 23, 2011
What model sub woofer can replace JVC SP-PW100?
open corel, at top click on about- click on activate and enter code
Sep 09, 2014 | JVC SP-PW100 Subwoofer
I have no sound coming out of my sub woofer on my kenwood VR-407 everything else works great anyone have any ideas or solutions
yes it very much has everything to with it. your sub out is at a pre-amp lvl, so you can route that signal to another amp, then to your passive sub, or get a powered sub
Apr 19, 2013 | Kenwood VR-407 Receiver
How do i connect the sub woofer for kenwood-505
I inherited a Kenwood SW 505 Sub woofer. I don't know if it works I plug it in but no lights.
Oct 07, 2012 | Kenwood VR-505 Receiver
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Sub woofer output port does not seem to work on my kenwood VR 407, checked sub woofer on another system - works fine, any easy solutions?
Dec 29, 2010 | Kenwood VR-407 Receiver
No Sound
This might very well be a fuse - check by setting the sub woofer to "On" to see if it powers up. If it does, there may be a problem with the sub woofer audio cable(s) or connection(s).
Don't forget to check for a tripped circuit breaker or blown fuse on the stereo's speaker output. If your sub is connected to a low level output - this shouldn't be a possible cause - as circuit breakers & fuses are usually on amplified (high level) or speaker outputs.
Another possibility is that the settings of the stereo has been changed from a *.1 system to plain stereo 2.0 or some other setting that disables the LFE (low frequency effects) or sub woofer audio output.
Sep 18, 2009 | JBL Venue SUB10 Subwoofer
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
Hooking up my sub woofer
Hi ..
According to the manual there's a pre-out (phono style RCA) connector for the sub but it needs to be a powered subwoofer..Has its' own internal amp
Jul 26, 2008 | Kenwood VR-305
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Sep 22, 2007 | Kenwood VR-507 Receiver
Kenwood VR-715 Receiver Logo
29 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
