BLUE RAY PLAYER WON'T PLAY THROUGH HDMI PORT
I HAVE A MAGNIVOX BLUE RAY PLAYER MODEL # NB500MG9. WHEN I HOOK IT UP TROUGH THE HDMI PORT ON BOTH PLAYER AND TV IT WILL ONLY PLAY MOVIE FOR ABOUT TEN SECONDS, THEN IT GOES TO A BLACK SCREEN, THEN BACK TO THE MOVIE AND SO ON. IT IS ACTING LIKE I AM SWITCHING THE INPUT ON THE TV BUT I AM NOT. IF I HOOK IT UP WITH NORMAL AV CABLES IT WORKS FINE BUT THE PICTURE IS NO BETTER THAN A REGULAR DVD PLAYER
  • dickey527 Jan 04, 2009
    I was able to watch about 2 movies before Christmas vacation. Now my TV says no signal from the HDMI ports. RCA cables play.
4 Suggested Answers
SOURCE: will not play Blue Ray DVD
I had the same problem. Try this. Contact Sharp and have them email you the firmware update. You will need to download it from the email and transfer it to the player via a flash drive. See if that works. I am about to return my Sharp Blu Ray player to Costco and go back to DVD. There seem to be a lot of problems with the technology. Even when movies start to play, they have freezes and it is sometimes hard to get the menu to show up
Posted on May 24, 2009
  • 1705 Answers
SOURCE: I put a regular dvd into my blu ray player but it
Assuming it will play regular DVD's I'd suggest you connect it by scart also and set your TV input to scart.
I don't think DVD's carry High Def. data, that being the case, your player may auto route the data via scart.
Posted on Mar 31, 2010
SOURCE: Until a week ago our Magnavox NB500MG9 blue ray
goes to stopped after the disc loads
Posted on Oct 01, 2010
easybill99
  • 993 Answers
SOURCE: new lcd tv and dvd player is playing movies in black & white
System settings--color-pal ntsc secam=auto
Posted on Jun 24, 2015
My mitsubishi tv has a phone jack looking plug then a anntena plug part , how do i hook up a dvd player to it
it could be an HDMI port for connecting HDMI cable. If your DVD player has HDMI output then you can connect it.
or it could be a usb port for playing videos from usb devices like pen drives and portable hard disks
i dont think tv has a phone jack
Feb 28, 2016 | Mitsubishi Televison & Video
How to hook up DVD player to 19' led HDTV
The modern way is to buy a HDMI Cable
Plug it in to the HDMI Port on back of DVD Player
Plug the other end into spare HDMI Port on LED TV.
Put in a DVD & hit Play
Use remote control to select HDMI port on LED TV
If it does not have a HDMI port then you need a converter box which picks up the Red & White (sound) & Yellow (viideo) and converts to HDMI standard.
Aug 13, 2014 | Televison & Video
2005 mitsubishi tv
I'm assuming that your new blu-ray player only has an HDMI port and your TV does not. In that case, does your tv have a component cable output? This should be five plug-in ports (red, white, red, green, blue). Amazon sells an HDMI to component adapter that you can buy here: http://www.amazon.com/eForCity-538581-HDMI-Cable-5-Feet/dp/B005QWH4QA/ref=sr_1_1?ie=UTF8&qid=1382102257&sr=8-1&keywords=hdmi+to+component+cable
Oct 17, 2013 | Samsung Televison & Video
Blue ray is hooked up to tv with HDMI correctly but there is no sound when playing the DVD
Check the hdmi port on you tv. There are some tv's that have an HDMI port that say HDMI/DVI(its a port for an older Digital Video that required seperate cable for sound), if this is the case then you need to hook it up to a different HDMI port on the tv because that input does not carry sound(you will see red and white audio inputs next to it) or use the audio outputs(red and white) cables and plug them into the out put of DVD player to the audio inputs that correspond to that same HDMI input. If this helps please rate me I do not get paid in anyway. I like to help people and want to make sure this is helping.
Dec 17, 2010 | Samsung Televison & Video
I have purchased the blu ray dvd player do i need to by a coaxial jack as well as the hdmi jack
No,a HDMI cable alone will do the job.Just plug the HDMI cable one side connected to the HDMI port hub belong to the tv HDMI hub,the other side of the HDMI cable connected to the HDMI port hub belong to the Blu ray dvd player HDMI port hub.That should play ur Blu ray dvd player.U still have questions,read ur owner manual.
Jun 24, 2010 | Televison & Video
Magnavox NB500MG9 BluRay Player
A Blu-ray player can play DVD or CD and still not play Blu-ray. It may play Blu-ray but not CD or DVD, or burned discs. This is all caused by the 'optical' a part that reads the disc in the machine. Your player will need service as a Blu-ray optic cannot just be 'dropped' into a player.
Mar 28, 2010 | Magnavox NB500MG9 BluRay Player
My Magnavox bluray disc player NB500MG9 will not play bluray dvds. Please help
My Blu-Ray will not play x disc
Mar 20, 2010 | Magnavox NB500MG9 BluRay Player
Televison & Video Logo
297 people viewed this question
Top Televison & Video Experts
Electro Med Services...
