Question about Fosa CY25 Laptop
LAPTOP DISPLAY, the brightness on my CY25 laptop is way to much. i tried pressing the fn key and using the up and down arrows, but even with the brightness turned down everything that is dispayed is still bright. for example, a color that is usually dark red is now a light red and it is very annoying. i cant even read some of the text on the screen because it is not even visible. i cant even see the lines surrounding this box that im typing in. PLZ HELP THIS IS VERY ANNOYING. and dont say change the video driver because there is already loads of problems with the ones out there for this module
Ok for some reason by running the game morrowind it fixed my display. Dont ask why, I dont know but thanks anyway. Maybe it has something to do with the mods that I have put on it.(morrowind)
Posted on Dec 15, 2008
How do I turn down brightness on my hp Windows 7 computer?
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Regards,
Rahul
Jul 15, 2013 | Computers & Internet
How can i turn down contrast on my laptop
Acer Aspire one
Brightness is controlled by the Fn and arrow keys.
Contrast can be controlled from the software.
FN key, + left/right arrow key's
other Acers
Log on to your Acer laptop and click on the "Start" button. Choose "Control Panel" from the menu.
Double-click on the "Display" icon in "Control Panel" and select the "Settings" tab.
Check the "Color Quality" settings and make sure they are set to either medium or high.
The high setting will give you better color quality and contrast, but it will also use more system resources and shorten battery life.
If you are operating on battery power you may want to move the setting to medium.
Hold down the "Fn" key and press the right arrow at the same time.
This key combination will increase the brightness of your screen.
To decrease the brightness and contrast, hold the "Fn" key down and press the left arrow. Continue using these key combinations until you have found the optimal setting for your laptop display.
hope this helps
Oct 08, 2012 | Acer Aspire One D255E13438 Netbook
How do I adjust the brightness on my laptop? Its a Compaq Presario V2140US
1. Press down the Fn key at the lower left end of your Compaq Presario keyboard. Keep the button held down and tap the F7 key to decrease the screen brightness by one step.
2. Tap the F7 key again with the Fn key still depressed to further decrease the brightness by one step. Continue hitting the F7 key until you reach the minimum LCD screen brightness.
3. Hold down the Fn key and tap the F8 key to increase the Presario's LCD screen brightness by one step. Keep pressing the F8 key until you reach the maximum brightness for your screen
Mar 01, 2011 | Microsoft Compaq Presario C501nr Notebook
My Laptop 6400 screen is very dark, how do lighten? I have replaced battery twice in last 3 1/2 yrs.
ldriscoll3:
The brightness of the screen does not generally depend on the health of the battery.
On the keyboard of your laptop is a "Fn" key. You need to press and hold the key down while you also press the "Up Arrow" key repeatedly. Each time you press the "Up Arrow" key while holding the "Fn" key down, the display will get progressively brighter until you reach maximum brightness. If you go too far and it gets too bright (not likely), just press the "Down Arrow" key while holding the "FN" key down until it's the perfect brightness
This is explained on page 33 of the user manual that you can download from here:
http://support.dell.com/support/edocs/systems/ins6400/en/om/MD4024MR.pdf
Thanks for using FixYA!
Feb 13, 2011 | Dell Inspiron 6400 Notebook
Cat sat on laptop changed screen brightness. its to dark how do i brighten monitor
There is a master function key that you hold down while tapping another function located on the keyboard. This all depends on the model of laptop. Next time try to giva a little more info like make and model, which is located on the bottom. The function key or Fn key is usually located on the keyboard near the Alt and Control key lower left. while holding this key down, you tap the corresponding brightness key on the number of the keyboard, some times the brightness is on the 4 arrows on the right side of the keyboard...sometimes they are the numbers 6 or 7 look for what appears to be a symbol that looks like the sun or a light. Hold down Fn and tap the key that brightens the display.
Sep 05, 2009 | Computers & Internet
How can I lower the brightness of my screen in my Dell 1525 lapto
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Jul 28, 2009 | Dell Inspiron 1525 Laptop
Dim monitor
I am assuming this is on your laptop display and not a monitor connected. If this is the case, you most likely pressed FN + the DOWN ARROW. You can use the FN key (usually on the left side near CTRL and/or ALT) in combination with the UP and DOWN arrows to increase/decrease the brightness. This is real handy when you want to have longer battery life as the lower the display brightness is the less power it uses.
Hope this helps,
Chris
Mar 23, 2009 | Dell Latitude D600 Notebook
Increase brightness
Press and hold the Fn key while pressing the up arrow key to increase brightness, down arrow key to reduce brightness
Feb 06, 2008 | Computers & Internet
Unable to adjust the brightness of display screen
bright ness buttons are indicted witha sun like mark . they r usaly used with fn keys look for that keys
Dec 22, 2007 | Dell Inspiron 9400 Notebook
Computers & Internet Logo
247 people viewed this question
Top Fosa Computers & Internet Experts
David Payne
David Payne
Are you a Fosa Computer and Internet Expert? Answer questions, earn points and help others
