Question about Magellan Roadmate 760 GPS Receiver
Roadmate 760 won't turn on..
When I plug the power adapter into the car , the screen flashes white and then nothing. I can't get it to 'boot.' Pressing the the blue power button on the left does nothing. If I unplug the power and plug it back in, same thing happens: white screen flashes for half a second and then nothing. I changed the fuse in the car adapter and had the same results. Thanks for and advice/help you can offer. -Joe
    Novelist:
    Scholar:
  • 86 Answers
White screen is giong to either be your LCD or Hard Drive. I would try changing out either one of these. If your warranty's out or dont' want to pay to send it in, then try this. Make sure the cables coming from the LCD to the mainboard (the large PCB (circuit board)), also, make srue the cable going from your Hard Drive to the Main board is tight. I'd even release each cable and plug them back in. Hope this helps. -Daniel
Posted on Mar 15, 2007
Roadmate 760 BSOD
A manual for your unit with troubleshooting guide can be found here.
May 14, 2008 | Magellan Roadmate 760 GPS Receiver
Window doesn't come on
That question does not reference what exactly is going on. Please step through from plugging in power adapter to power from wall outlet and pressing the power button.
ie: 1) plug in power adapter (i see charging light)
2) pressing power (i see boot screen logo)
3) next screen (i see windows boot logo)
.... and so on...
Jan 16, 2013 | Fujitsu LIFEBOOK NH532 Notebook
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Laptop won't switch on although blue power light on is showing power is getting to the machine
Check the power adaptor led is not flashing. Flashing Adaptor LED indicates fault with laptop charging circuit / powerboard
If it will not boot on battery, and you know the adaptor to be good, the issue lies with the motherboard.
Sometimes, removing the battery, and unplugging, pressing the power button and holding it for 30 secs, replacing the adaptor only will allow it to boot up, but this will only work if the motherboard is not damaged r the CPU fan has not failed.
Jan 27, 2011 | Toshiba Satellite P200-13Z Laptop AC Power...
Its my sister's toshiba a205-s4577 it does not boot up at all. when i plug in the ac power, the blue plug light goes on, but when i press the power button, all the lights flash for a second and then...
Hello.
The most common reasons are the battery, power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Also, power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you are knowledgeable, remove the heatsink and apply new thermal paste.
But, it certainly could be the mobo.
Hope this helps.
Jan 24, 2011 | Toshiba Satellite A205-S4617 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Computer comes on and I only get blue screen. Taken battery out, turned electric plug off. Hit start button 30 seconds, then plugged up electricity, started machine, still nothing happens. What other...
Another suggestion is to take the power out, remove cables and battery then press and hold the power button for 10 seconds. Then reinsert the cables and battery and turn on the pc. If the blue screen still appears, take note of the blue screen error and try to boot to safe mode with networking. If you have a recovery disc, boot it by pressing F12 repeatedly in startup to run the check disk. If did not work, then you have no choice but to reinstall the operating system...
Jun 19, 2010 | HP Pavilion tx1000z Notebook
Travelmate 2300 does not boot up ... pressing the power button (with battery installed and with AC adapter plugged in) momentarily starts the internal drive ... then it gos quiet. Power light remains on...
Turn the system off....remove the battery from the system...connect the system to power adaptor ONLY.. the keep pressing the power button for about 15-20 seconds...then try to turn on...check if the system boots... let me know if the system works or not
Jan 15, 2010 | Acer TravelMate 2300 Notebook
What size fuse goes into the cig lighter adapter for the magellan roadmate 760
size or value?
4 amp is what are placed in them at the tip.
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
206 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
