Question about Indesit Dishwashers
Indesit evolution de43 error a02 - Indesit Dishwashers
Can my dishwasher start leaking with putting too much salt in it?
Posted on Apr 21, 2010
What does code F-10 means?
F10 is a pressure switch fault which could just be the pressure chamber is blocked and needs cleaning out
use this link for error code Domestic Appliance Help
Oct 03, 2016 | Indesit Washing Machines
Sulla mia lavastoviglie indesit de 74 evolution mi appare il codice di errore a12 mi sapete dire cos'?. Grazie in anticipo Fabio
Ciao Fabio.
A12 significa che c'e' un problema con il circuito di riscaldamento dell'aqua. A12 appare quando il modulo di controllo rileva che il circuito che include l'elemento e'aperto.
Elemento e circuito devono essere testati con il multimetro. Se l'elemento e' aperto deve essere sostituito. Se i cavi e l'elemento sono a posto, allora il problema e' il relay integrato nel modulo di controllo.
Il caso piu comune consiste in un elemento diffettoso.
In bocca al lupo.
G.
Dec 08, 2011 | Indesit 24 in. DE73 Evolution...
Indesit dish washer is showing error code A08 why
from what i can find out, it means (auxillary wash pump triac cloesd/open circuit)
Sep 25, 2011 | Indesit 24 in. DE73 Evolution...
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Error code a14 on indesit evolution de73
A fault with the water heating has occurred. Book a service engineer
Sep 07, 2009 | Indesit 24 in. DE73 Evolution...
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Indesit evolution DE73 frozen program
I have the same problem. You need to switch it off at the mains for at least 20 mins.
Aug 14, 2007 | Indesit 24 in. DE73 Evolution...
Indesit evolution de 73 dishwasher with an AO5 error code
a05 is pressure switch not reset. check for blockages in the drain pump, filters and sump
May 06, 2007 | Indesit 24 in. DE73 Evolution...
AO2
The filter is blocked with food debris. Remove the filter by lifting the triangular-shaped plate from the bottom of the dishwasher. Then lift out the mesh cylinder-shaped filter from beneath it. Rinse both under the tap and replace.
Aug 20, 2006 | Indesit 24 in. DE73 Evolution...
Dishwashers Logo
539 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
