Question about Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16
Swingline Stapler Staples Only After You Open It Up....
I have a swingling heavy duty stapler and it does staple but only after you open up the top of it [as if to put more staples in it]. I think there is a problem with the spring but i am not sure how to fix it. And I have the right staples for it, heavy duty ones that have the model of the stapler on the box.
The Model #: 77701/15
Thanks, Sarah
  • 3 more comments
  • Michi-chan Feb 13, 2009
    I have the same problem! The only way to make it staple again is to bang the head of the stapler on a hard surface. It then puts the staples back in the right spot to be able to be stapled again.
  • Anonymous Mar 18, 2014
    I think it provides tension to lift up that part of the stapler that houses the staplers.
    The spring fell out and now the stapler handle does not lift stapler head
  • Anonymous Mar 20, 2014
    How do you open up the stapler
  • Anonymous Mar 26, 2014
    I need staples for the 10060 model.
    New Friend:
  • 40 Answers
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
  • kozmikkurt Mar 14, 2009
    Also, here's some directions from Swingline about clearing jams from manual heavy duty staplers:
    My heavy duty Manual stapler is jammed how do I clear it?
    Question
    Answer
    When you jam staplers in your Heavy Duty Manual Stapler, such as the 90002, 39002 or 39005, you can remove the staple jams by using the following steps.
    1. Remove the follow block at the back of the stapler, by pushing the follow block in, lift the follow block up slightly and slide the follow block out of the stapler.
    2. Remove any staples which are on the internal staple rail. They should slide out of the back of the stapler.
    3. On the front of the stapler there should be a plastic covered tab. This tab is on the Front Face Plate. Hold the handle up, and push down on the tab with the side of your thumb. The Face Plate should move down and release. Once the front face plate is released you can open the Front Face Plate out at a 25-30 degree angle. Check the inside of the Front Face Plate for any damaged or broken pieces of staples. Remove any damaged staples that are found. ( If you have numerous staples jammed in the Front Face Plate, remove as many of the staples as possible with a needle nose pliers first. This will make opening the Front Face Plate much easier.)
    4. While the Face Plate is opened, place your Follow Block back into the stapler, you want to see the end of the Follow Block come out through the front of the stapler. If you do not see the Follow Block come out of the stapler it means that you have staples jammed inside the stapler on the rail. Proceed to step 5
    5. Remove the Follow Block out of the stapler. To view the staples jammed on the rail, look down the inner rail from the back. The staples will generally be going across the top of the rail. You will have to look closely to see these staples. Once you have located the staples, insert a long thin bladed screw driver through the staple rail, once you are under the staples, lift the blade of the screw driver up underneath the staples and slide the staples backwards out of the stapler. After you have removed all of the staples, try to slide your Follow Block back into the stapler, and again you want to see the end of the Follow Block come out of the front of the stapler.
    6.You will now need to close the Front Face Plate by following these steps:
    * Pressing the face plate back in towards the stapler.
    * Hold inward pressure on the Front Face Plate.
    * Lift the Front Face Plate up until the Face Plate locks back into position.
    * DO NOT TRY TO STAPLE UNTIL THE FRONT FACE PLATE IS LOCKED BACK
    INTO POSITION AS LEAVING THE FRONT
I have a 77701/15 model swingline with the same problem. It was the as kosmikkurt had described: the pusher was not sliding smoothly. I spent so much time adjusting the "bend" in the pusher that i didn't realize it was the channel slot that had the problem. Basically, my pusher was sliding out of the grooves because the slot got "widened" somehow. All i did was use a pair of pliers to squeeze the wider section so that the channel was parallel and now the pusher stays within the grooves. Simple as that.
Posted on Apr 08, 2009
Where do I get staples for a B&D stapler? #9700
There are several brands of staples that will fit your stapler and the price will vary according to the depth of staple you are looking to buy. Arrow brand staples are the most common. All the ones I saw that fit the 9700 are Wide Crown Swingline Heavy Duty
Arrow 606 Wide Crown Swingline Heavy Duty 3 8 Inch Staples 1 000 Pack
Jan 06, 2015 | Staples Tools & Hardware - Others
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
Who sells staples 101 4 for a swingling 101 stapler
Hi, you can purchase them on amazon, here: Amazon com swingline 101 staples I hope this was helpful. Have a nice day
Jul 28, 2012 | Swingline Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
Trying to load the staples into a model #90010. They're fine except at the very front of the stapler, they wont go all the way down flush with the others and the chamber won't even close.
1. Make sure you have the correct staples for the machine, Swingline Hvy-Duty Staples for 90010 Stapler, 0.625-Inch Leg Length, 2500 per Box (90009)
2. Check the staples to make sure there are no visible jams. Remove some staples from the row if this helps them fit.
3. If you continue to have problems, contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
They will replace the stapler if needed.
Apr 14, 2011 | Swingline ® LightTouch Heavy-Duty Stapler,...
Optima Model # 8787x. Appears to be jammed. How do I open up the stapler to remove cause of jam. I think if I could open it up I could fix it. If all fails can this be sent away to be fixed and...
You need to open the stapler from the back. Push the black piece at the back of the stapler in, then pull it up and out. Remove the jammed staples, and reinstall. Make sure you use the correct staple . It appears to be: SWINGLINE 35550 HIGH CAPACITY STAPLES, 3/8"
Apr 13, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
How to load staples?
  1. Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
  2. Load the heavy duty staples into tray.
  3. Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Resource 1 : eHow Article
Feb 21, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Instructions on how to load a swingline heavy duty stapler.
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Aug 13, 2010 | Swingline Heavy Duty Stapler 30 160 Sheet...
Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16 Logo
14,545 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
magna buff
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
