Question about Dell 540 Photo Thermal Printer
My Dell 540 printer only prints 1/2 (upper) of the photo
I uninstalled and reinstalled the software but still doesn't work
    Scholar:
  • 107 Answers
Do you have any other devices installed on the machine that are also parallel (hard drive, CD/DVD drive, etc.)? This may cause this reaction.
Is this a laser printer? The drum may not be holding a charge.
Are you sure the driver installed is the correct driver? That may be the issue as well.
Posted on Jan 03, 2009
Printing problem
uninstall software and reinstall
Jul 06, 2009 | Dell 966 All-In-One InkJet Printer
Dell Photo 926 printer scanning problems
Go to Control Panel, then Programs and Features. Uninstall the Dell printer software.
Then, go to Control Panel, then Device Manager. Locate the printer, right click on it, and select uninstall.
Disconnect the printer from your PC.
Go to the Support section of Dell's web site, download the latest driver for your printer.
Restart your PC.
Install the software. Connect your printer when instructed to, or after the software install has completed.
Let me know if you still have issues :)
Apr 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
C++ Runtime Error for Dell Photo AIO 962 printer dlbxmon.exe
I had the same problem and was able to fix it by following the instructions in this link:
http://forums.cnet.com/5208-7590_102-0.html?forumID=67&threadID=300180
Apparently, the regular uninstall procedure does not completely uninstall the software drivers. Then, if new drivers or software are installed, a conflict is created between the old drivers and the new drivers. You have to first run the DellXPCleanUpUtility to completely clean out the old software drivers. Then, you can install the new drivers successfully.
Jan 02, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell 540 photo printer
It might be time to, but try these first:
(1) Try rebooting the computer (Press Ctrl+Alt+Del>Shutdown>Shutdown OR press and hold the power button down on the front of the workstation/computer/tower/CPU until the unit turns OFF)
(2) If that doesn’t work, then try clearing the print queue: Start>Settings>Printers>Double-click on the printer>Right-click on the print job(s) and click cancel/delete/purge documents and try reprinting a document
(3) If that doesn’t work, then try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print
(4) Run a Test Print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
Jan 02, 2009 | Dell 540 Photo Thermal Printer
Dell 946 will not print after one print
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Dec 19, 2008 | Dell Photo 964 All-In-One InkJet Printer
email me at kissnickerson@gmail.com and I will tell you how I got mine to prin the whole picture again.
Dec 03, 2008 | Dell 540 Photo Thermal Printer
1720dn dell
Normally to fix a printer that is printing gibberish, uninstalling and reinstalling the print drivers will fix this issue. Another thing that can contribute to gibberish print is using a USB cable that is too long.
With this particular problem (prints Zen), one solve is to uninstall any Dell toner management software. This is particularly true if you are running Vista and hooked up by USB. To uninstall the toner management software (Vista OS), go to control panel>programs>programs and feature>uninstall a program. From this list choose Dell software, choose a customized uninstall, and then choose anything that has to do with Dell toner management.
Sep 15, 2008 | Dell 1720dn Laser Printer
Looks like to heaters are going How long have you had it Still under warranty? If so send it back or ask for a replacement.
May 22, 2007 | Dell 540 Photo Thermal Printer
Dell 540 Photo Thermal Printer Logo
164 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
