Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Suggestions for cleaning the genn air stove top JDR8895aas
I have scrubbed with soap & water, it just does not get clean and shiny(still looks dull and dirty). Should I try Cerama-Brite?? Is it safe for my Genn Air....What else can I try for a clean stove top???
  • 1 more comment
  • antonia_turc Dec 19, 2008
    I have the same problem. I've tried every stainless steel cleaner available and nothing works. I'm starting to think it is a manufacturer defect.
  • Anonymous Jan 26, 2009
    I also had several spill-overs on my Jenn-Aire stovetop---what can I do? Water and soap will not remove them.
  • titles Feb 22, 2009
    Same problem, no matter what I do the burner area looks dull and won't clean up. Any help out there?
I have no solution but I have a Jenn-air stove, white with dual fuel and the oven door is badly stained on the top, probably from the vapors when self-cleaning. I have tried many things and they won't touch it. can someone help me out
Posted on Oct 24, 2009
How do i get ceramic tiles to have a shine again. they are not high gloss but they used to have a shine to them
You might try a steam cleaner like the Shark Steam Cleaner. If you use a polish, sometimes that makes it worse and makes your tile dull. Just use plain old soap and water. The Shark also scrubs your floors as it cleans.
Feb 13, 2015 | Vacuums
How do I clean the screen for my wd 73c9
I use a very slightly damp cloth with just water. Soap can dull the screen. Wipe lightly. Don't scrub or you could gouge lines. Dry with another cloth immediately.
Jun 04, 2014 | Mitsubishi WD-73C9 73" DLP TV
Cleaning the stove top.
Have you tried oven cleaner? Use the fumless type, otherwise yo will be overcome by the fumes. Clean the grill just like you would an outdoor BBQ, wire brush, the coat it with a light oil to prevent rusting.
Mar 31, 2010 | Thermador PD364GLBSS Dual Fuel (Electric...
What's the best way to clean gas stove top pieces?
Remove from stove soak them in a sink of hot water and bleach for about 15 min then lightly scrub with scouring pad and they should come sparkling clean.
Jan 28, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
How can we clean our enamel black top stove
I use Vim creme cleaner. Police use it to polish the chrome on their guns. Using a paper towel squirt a tablespoon or two all over black stove top (I have a gas one) Then with a wad of wet paper towels scrub and clean off all the dust, grease and water spots. For the final step, get a dry, soft towel and rub to a nice shiny finish reoving the residual Vim streaks. Works very well and does not take a lot of time.
Oct 04, 2009 | Frigidaire FGF316 Gas Kitchen Range
What is preferable - a stainless steel gas stove top, or a black?
black enamel
heres why
salt and grease get baked to the stainles steel
most scrub to get clean
very quickly this dulls and eventuly wears the steel and it looks drab
the enamel will alwsys look good
Oct 03, 2009 | Kenmore Kitchen Ranges
Top burners spark intermittently with burner valves shutoff
Remove the burner caps (where the gas and flame come out) and wash in warm soapy water, using a plastic toothbrush like brush to scrub thoroughly.
Also clean/scrub the burner bases and ignition knob on the top of the cooktop.
When you reassemble, make sure the burner caps are properly seated in the burner bases.
Jan 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Igniter of back burner dies not click or light
I had the same issue with washing the top with water and cleaning solution. I had arching, eventually one burner failed to ignite. I tried the above solution and it did not work. Remove the ceramic top on the burner that will not ignite. Turn on another working element. Do you see the igniter working?
If so slowly turn on the gas on the failed burner and it will ignite. I'm looking into what component automatically controls the igniting and gas release when the knob is turned on.
Dec 22, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn air range
1.black top nice and shiny, as far as streaks your gonna ahve to find a cleaner that works for you , i have a black cooktop and my wife uses clorox wiped to clean and then with paper towel wipes off and dries
2. as far as "saddle grill" calling the manufacture (number inside your manual) will be best source of info on that, of course unless you can find an aftermarket 3rd party maker
Mar 15, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Cleaning
The firstly the top is like a beautiful shiny black car. It dazzles the eye when clean, but shows every little mess and evaporation spot when it is not. The worse problem is grease. Both on the top and on what you wash and dry it with.
At the end of each day, I use a solution of dish washing detergent and hot water to clean the top. I let the solution sit on the top for several minutes, then rinse it off with a clean rag and hot water. Then I do it again. I use a paper towel to dry the top. At first, you think you are leaving streaks, but these are small evaporation trails. Just keep on drying and the steaks disappear.
Nov 18, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
776 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
