Question about Whirlpool ET1FTKXK Top Freezer Refrigerator
Water dripping inside fridge
Inside the refigerator, there is water accumulating towards the back of the shelves. it looks like it is coming from the vents in the back of the fridge. it also ends up accumulating under the crispers.
  • 3 more comments
  • thomas gardy Mar 16, 2007
    catriver,you were right on the money with your solution.the drain tube was frozen over.thanks for the help! jeets
  • ks121 Jan 08, 2008
    I've done as suggested, taking everything out of the freezer and clearing the drain with hot water. Start to finish it takes about three hours. My problem is that within a month it is clogged again and ruining my produce! I live in an arid climate, and doubt that humidity is the sole culprit. Is it possible the condenser is bad, or maybe the seal around the door is faulty?
  • Anonymous Sep 03, 2008
    Defrosted th have water in the bottom and frost in the freezer again.
  • Anonymous Feb 16, 2009
    water coming in back vent flooding the shelves and under the crisper it sounds like a clogged or frozen drain tube how do i fix this?
  • Anonymous Apr 01, 2014
    every 5 days or so, water accumulates inside the optibin crisper bins...any idea where it is coming from and, of course, how to fix it?
    President:
  • 878 Answers
Jeets, remove the bottom panel from the freezer by removing the 2 quarter inch screws up front. See if you have a sheet of ice under it. If you do, you probably have a frozen drain tube in back. When the unit goes into defrost the water is running down the air vents instead of the drain tube. If this is the case, you will have to remove the back panel in the freezer and clear the drain hole. Use hot water if it is frozen over....Catriver..post back.
Posted on Mar 15, 2007
  • 944 Answers
Here is the link to the manual if you need it; http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/2314472.pdf especially this time of year there can be a massive increase in humidity which often is the cause - the only real cure is to dehumidify the room and try and limit how often you open the fridge. even if the water seems like too much for this to be the cause, you would be surprised how much condensation humid air can produce - I assume everything else seems to be working as normal? ask again if you don't find what you need. check this link too; http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_alp.php?p_page=1&p_cv=1.113&p_pv=1.137&p_prods=137&p_cats=113&p_search_text=&p_new_search=1 Hope this helps :)
  • 145 Answers
Add a short peice of aluminum wire wrapped around the heater going about two inches into the drain hole. This acts like a heat sink to keep the drain warm till the water runs down the hole.
Posted on Apr 17, 2008
A repairman replaced a timer that controlls the auto-defrost cycle three months ago. I haven't had to defrost since then, and find that my milk doesn't go bad as fast.
Posted on Mar 24, 2008
I have the same problem, every to months after cleaning freezes up again. Just ordered a heat probe from whirlpool $15. It is suppose to keep it from freezing up.
Posted on Mar 17, 2008
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Apr 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Water accumulation underneath the bottom vetable
Two solutions
1 If a frost free fridge/freezer - ice build up in internal cooler - defrost totally until no more water
2 if ordinary fridge/freezer look inside at the back, you should see a very shallow 'V' shaped plastic channel running to a small drain hole which leads to the rear outside of the unit. This channel collects the water drips from the cooler
Clear this hole with a pipe cleaner or cocktail stick or similar
Sep 27, 2009 | Samsung Refrigerators
Water leaking inside fridge.
If you remove the back panel of your freezer you will notice what looks like a drain - melted water will go through a drain hole that extends to your refrigerator inside a cup that slowly drains the water through a tube through the back of your refrigerator and down the drip pan. Your cup may appear fine, but maybe there is some obstruction somewhere causing the water not to drain fast enough - so what happens is that the cup will eventually overflow - try to see if you can remove this and pass a long wire down the drain tube at the back to dislodge anything blocking or partially blocking it - see if you can also clean your drain cup, eventually small derbris accumulate. At the back of your freezer panel look for any partial or complete obstruction of the drain hole and its surroundings, which might be iced up.
I myself have had this problem for months, my refrigerator would have water at the bottom accumulate and eventually under the crispers a river of water :)
Cleaning the cup and the drain tube at the back of the fridge and the drain and surroundings at the back of the freezer panel should fix this problem. Sounds like your drain at the freezer level is plugged up and water is backing up and leaking from elsewhere !
Sep 25, 2009 | Frigidaire PLHT219TC Top Freezer...
Water accumulates inside the refrigerator, Kenmore, Mod. 71194100
You get to it from the freezer. Remove the back wall in the freezer and you will see it there. Unclog it with some wire or check to see if it has ice over it.
Sep 13, 2009 | Kenmore 71112 / 71114
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
May 10, 2009 | Refrigerators
Water accumulation under crisper bins
Check that the hole at the back of the fridge is not blocked with gunge.  There should be a drip tray at the rear with 2 slopes towards the hole where the condensation drains to.  Some cabinets come with a little rod to clear the blockage.  The rod may live in the hole alowing water to drain around it.  Have a peek!
Feb 22, 2009 | Frigidaire FRT18S6AW Top Freezer...
OK, i see a lot of this, and on a fridge that is nearing 10 years old, its pretty normal. Now, we all know that water is leaking into the fridge section from up top because the drain is plugged that is under the evaporator.. now to fix the WHY it happened. most of the time this will happen because the fridge did not go into a DEFROST cycle for a while.. reason being one of two things... either the defrost timer has quit working, or the bimetal thermostat sensor that is clipped on the evaporator has failed. the bi-metal thermostat is usually located in the freezer behind the rear wall and looks like a round "clip on" with 2 wires coming off of it. one pic of one is here.
http://www.partselect.com/PartDetail.aspx?Inventory=371255&SourceCode=5&ModelNum=et18pk
instructions on how to test this is shown on the link.
(just replaced mine the other day, NO MORE WATER LEAKS! =) )
hope this helps!
Chris
Jun 15, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Leaking Whirlpool refrigerator
My Whirlpool fridge had water droplets falling onto all three shelves and pooling unter the crisper drawers. I solved the problem by clearing the ice-clogged drain in the freezer.
In Whirlpool model ET21UM, the condensation drain hole is located directly behind the freezer. To access the drain hole, remove all your frozen items and place them in a large picnic cooler. Notice that the floor of the freezer is basically a large plastic tray fastened by two small bolts. Unscrew the bolts with a wrench or ratchet and remove the plastic tray. At this point you will probably see that water has seeped under the tray and created a mini ice rink on the bottom of your freezer. You can tap the ice lightly with the handle of a screwdriver to break it up. Once it's broken, toss the ice into your sink, or put it in a plastic bag and store into your cooler to keep everything cold.
Once the ice has been removed from the freezer floor, you should be able to see a metal drip trough in the back under a false wall hiding the condenser coils. It's a little tougher to remove the ice from the drip trough with the screwdriver method, so you might want to use a hair dryer. After a few minutes with the hair dryer, you should be able to remove most of the ice by hand. You can remove any water with a sponge or turkey baster. The only ice left will be a plug of ice in the drain hole in the middle of the drip trough. Heat up a cup of water in the microwave and carefully pour it into the drip trough. If the drip trough is hard to access, you might need to use a funnel. The hot water should melt most of the ice in the drain hole. If it pools in the drip trough and doesn't drain, use a sponge or turkey baster to remove the water and add hot water again. A small length of wire or a pipe cleaner might help clear any other obstruction in the drain hole. When the drain is clear you should hear water flowing through it. Dry off the floor of the freezer and return the plastic floor tray to it's spot and fasten with the two bolts. Remove any water that has pooled in your refigerator and you're done.
Dec 27, 2007 | Refrigerators
Whirlpool ET1FTKXK Top Freezer Refrigerator Logo
759 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
