Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Screen resoltion not higher than 640 by 480
And color quality is the lowest.. I just moved my computers location .. and it def. did not have this problem before.. please HELP
  • speedy12x Jan 02, 2009
    Like pati22 I moved my computers/monitor etc for the holidays. When I moved it back my screen was mostly green. I tried it on both of my laptops with the same result. I tried your suggestion but when I open the system menu there is no video tab (windows XP). I did go into display properties and tried to update the driver but I got a message in the update wizard that the wizard could not find a better match.
    With this screen it is easy to change the adjustments by mistake as you touch the side to turn it on or off and you get into the settings. I thought perhaps I just set something wrong by accident, but I have tried most of the adjustments without any luck. I only moved the equipment a few feet and didn't drop anything or bang it. Thanks
    Problem Solver:
  • 12 Answers
This sounds like a video driver problem. If you go to start ->control panel->system and look at the video tab you may see a exclamation point. Right hand click on the video tab-> click properties->update driver and take defaults.... since you didn't have the problem before the driver should be located on your hard drive. Good Luck! Michael
Posted on Dec 14, 2008
I can't change screen resolution on Lenovo L171 Monitor.It is set on 640 by 480 pixels and 16-bit color quality.I entered the properties options in Control panel>Appearence and Themes>Display and...
The problem is not your monitor, it is your computer. It sounds like the computer is operating off a standard vga driver that comes with windows. You need to locate and install the specific driver for your onboard chipset or add-on video card. I would be more specific but you haven't posted any info on your computer.
Apr 13, 2017 | Lenovo L171 17" LCD Monitor
Color quality is lowest (4 bit), cannot change also font is very large and I also cannot change.
The video driver is missing or corrupted. Go into Device Manager - Display Adapters - your video card and right click on it and uninstall the driver from there. Reboot , go to the manufacturer of the video chip and download and install a new one.
Jul 05, 2010 | Gateway FPD 1730 17" Flat Panel LCD...
How do i remove input not supported from my screen before i put the screen in the garbage
You get the 'not supported' due to the video resoltion from your PC is higher than what the monitor can support.
AL1916W has 1440 x 900 Native Resolution
Nov 25, 2009 | Acer AL1916W 19" LCD Monitor
Medion monitor shows analog out of range and will not turn on
Two options here. 1) Boot into safe mode, open control panel, display, settings, change the screen resolution to the lowest setting and color quality to their lowest setting and reboot. If that works move your setting up to where you used to have it (i.e. 800x600 pixels. Another option is to use System Restore to restore your system to an earlier date...a program you recently installed could be the culprit. System Restore is located at Start, All Programs, Accessories, System Tools.
Jan 14, 2009 | LG Flatron L1750S 17" LCD Monitor
Color quality
re-install the drivers for the video card and the cdrom drive. win xp should have all the parameters for the machine
May 23, 2008 | Computers & Internet
Color quality
Windows has lost the display driver for your particular card. You will need to determine what the card is (it may say when you first start the machine) and redownload the drivers for it.
Vertical screen lines and resolution is in extra large format.
Possibly either or a hardware fault..
Does the pc have an external monitor port? Most do.. If you can get another monitor, plug it up and use the correct hot keys (keys on your keyboard) to switch between the laptop monitpr & the external, it might help diagnose the problem. Maybe select a generic driver for the external monitor.. Although the pc will probably pick it up ok. If you need further help, let me know. Rgds.
May 02, 2008 | Dell Inspiron 8200 Notebook
Emachine 15' lcd monitor
Your query - "can the monitor work with an older HP computer?"
Normally yes, assuming that there is no hardware fault. The message is an indicator that somehow the settings of the display of the old HP computer does not match that of the Emachine 15' LCD monitor.
Perhaps what you can do is to run the old HP PC in Safe Mode (press F8 before Windows starts), using the arrow keys, select top mode setting in the Menu which is Safe Node, hit enter. Windows should then start and normally should be viewable no matter what settings the monitor can handle. On Safe Mode Windows, right click on any clear area of the desktop, click on properties, Settings tab, move the Screen resolution to the left most position, set the color quality to the lowest possible choice. Click on Advanced button, click on Monitor tab, set Screen Refresh Rate to lowest possibler, OK, OK, reboot.
Hope that this be of some help/idea. Pls post back if things worked out or should you need additional information.
Good luck and kind regards
Dec 09, 2007 | E-Machines eMachines Monitor E15T4
How do i connect my laptop
Assuming that the laptop is hooked up to the projection TV using the correct cables or connectors and still no video display on the TV, perhaps you need to lower down the laptops screen resolution first using your laptop's screen display before pressing the Fn + F? key.
To lower the screen resolution, right click on any clear area of your desktop, select Properties. click on the Settings tab, move cursor of Screen resolution to farthest left, Apply, Color Quality to lowest, Apply. Additionally, click on the Advanced button, Monitor tab, select lowest Screen refresh rate.
Hope that this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
