Question about Garmin GPS 126 GPS Receiver
Identify Bulkhead Plug
I've got a Garmin 126 GPS on the bench at the moment with pin 1 on the main connector corroded to the point where it has broken off completely. Since this pin carries power to the unit, that's bit of a problem for me. Does anyone know what series this seven pin so-called-waterproof bayonet locking bulkhead plug comes from ? Thanks, A.
  • Alastair Macleod
    Alastair Macleod Mar 15, 2007
    Thanks - the link to LTW looks particularly promising.
    A.
  • 944 Answers
Here is the link for the manual if you need it; http://www.garmin.com/manuals/82_OwnersManual.pdf page 59 has a wiring diagram which i guess you may have seen check this link - http://www.ltw-tech.com/c.php?idc=1&cs=&ms=&cb=&as=&task=part these guys seem to have the right ones Hope this helps :)
Posted on Mar 15, 2007
Where can I have my Garmin GPS126 Receiver repaired?
Search for an Authorized Service Center in you locality.
Apr 26, 2014 | Garmin GPS 126 GPS Receiver
My garmin gtm21 lead has broken
Read this post for the pin-outs.
http://www.gpsdiscussion.com/garmin-gps/7316-gtm21-pin-outs.html
Feb 08, 2010 | Garmin StreetPilot c510 Deluxe GPS...
No power in fuse panel (5a access/hazard) or brake lights
If there is no power in a fuse panel for ANY of the fuses, suspect the wire harness bulkhead connector. The harness comes into the firewall from the engine compartment, as a Male connector. Under the dash the bulkhead connector is a Female socket.
There are individual socket holes for each one of the fuses, on the Female bulkhead connector. There are flat bladed pins for each fuse on the Male bulkhead connector.
Upon separating the Male bulkhead connector from the engine compartment, inspect the individual connections. You may see some that are burnt, or corroded. They may even be melted! (The machine screw heads are on the interior side. You have to remove them. There is a rope gasket made of a sticky substance, {Name escapes me at the moment}, that makes separating these connectors Fun! {?)
This could be the problem.
Apr 09, 2009 | 1972 Chevrolet Corvette
Unit is not turning on.
Hi - check power is getting to the plug at the GPS socket. Use a voltmeter or bulb to check the pins 1 and 2 - these are the first 2 hole on the clockwise side of the notch in the end of the plug.
Positive is the first. Negative the 2nd hole.
See Garmin diagrams here: http://www8.garmin.com/support/faqs/faq.jsp?faq=68
If there's power there then you'll have to undo the screws on the back to have a look for any obvious faults but these are pretty robust machines so I'd be picking your cable is suspect first.
Can you let us know the result?
Thanks - Tony at KiwiGS
Apr 01, 2009 | Garmin GPS 126 GPS Receiver
Malfunctioning Garmin GTM 20 fused GPS power adapter
The two red wires are +VE Supply and both connect to pins 1 and 2
The two brown wires are Supply Ground and both connect to pins 8 and 9
Pins 3 through 7 are the traffic recievers digital interface:
Purple/violet connects to pin 3
Yellow connects to pin 4
Blue connects to pin 5
Black connects to pin 6
Green connects to pin 7
Dec 30, 2008 | Garmin GTM 12 FM TMC Traffic Receiver...
Broken USB Connector (Garmin nuvi 200)
USB connectors are too fragile for the constant in-out service they get. But I have solved the problem, at least for standard Type A. The plug end (its steel case slips into the port end's steel case) is functionally female; it accepts the 4-pin tongue of the port and squeezes it between the 4-pin tongue of the plug end and the steel case of the plug end. So when the plastic tongues wear down, the squeeze isn't tight enough. Solution: take a small vise-grips and make the plug's steel case a little thinner, like a weight on a grilled cheese sandwich you're making. Then when you plug it in, it will resist a bit and feel tighter. And it will now work!
Nov 20, 2008 | Garmin nuvi 200W GPS Receiver
Internal wiring
Hi - I have a Garmin GPS 126 in bits on my desk ready for a new cable as the socket in the back has some broken pins.
Also refer to the Garmin GPS to PC Wiring Instructions here on the Garmin site: http://www8.garmin.com/support/faqs/faq.jsp?faq=68
The internal 8 pin white connector on to the back of the circuit board is as follows:
1 Red Positive
2 Black Negative
3 Yellow Data Out
4 Green Data In
5 not used
6 not used
7 White Alarm
All the best, Tony at KiwiGPS, New Zealand
Jan 23, 2008 | Garmin GPS 126 GPS Receiver
No power
Could be worth a look at the connector on the back of the unit itself. As I discovered a few weeks back, they aren't as saltwater resistant as the IP67 rating would lead you to expect. Compare the pins in the plug with the diagram on page 99 of your manual (also downloadable from http://www8.garmin.com/manuals/GPSMAP198CSounder_OwnersManual.pdf) and make sure all the pins that are supposed to be there actually are. In particular, make sure pin 15 is in a decent state. This one carries power to the unit, but will act as a sacrificial anode in the presence of saltwater, and can rapidly corrode to oblivion. If this is what has happened, you have a bit of a problem, because Garmin, don't appear to be very good at making spares available. I was lucky in that the GPS I was fixing was a lower end model that only used five of the seven pins in its connector, so I was able to rewire to provide a supply through the unused pins. The diagram suggests that the 198C also sports a few unused pins, so you may well be in luck. A.
Apr 14, 2007 | Garmin GPSMAP 198C GPS Receiver
Garmin GPS 126 GPS Receiver Logo
176 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
