Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer & the clothes will not spin out the water when the washer is done they are still soaking wet?
    President:
  • Whirlpool Master
  • 2,651 Answers
Possible that with the machine not draining, its not going to high speed spin try this:
you can access the drain pump assy by removing the 3 screws across the bottom of front panel, after that youll see the drain pump directly in front of you, youll need to unscrew t he filter cap form the "button trap"assmebly, this is what catches all the junk left in pockets, or the baby socks, so they dont make itr into the puppmp itself. be warned there will be water wanting to come out after unscrewing the cap. ALOT depending on amount of water in machine!!!!!!
Posted on Dec 15, 2008
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
My whirpool duel washer agitates or washes but
have you replaced the motor control. i had this happen 1 year ago and had to have it replaced. i am having the same problem and have done some testing but have not found anything else. you can buy this part from whirpool for about $160 delivered to your home. this is exactly how it acted the 1st time it went out. some loads would spin out great and the next load would be wet.
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes come out soaked
You water is not being pumped out when the spin is on; this is due to the outlet filter being blocked. Find out where this is from your users'manual and clean it out. This is to be done periodically according to your usage.
Jun 18, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
89 people viewed this question
Dan Webster
Dan Webster
Sal De
