Question about Linksys WRT160N Wireless Router
I have a linksys router i am trying to connect my laptop to the router but is not working is say validating network and some time saying duplate network
    Genius:
  • 1,061 Answers
LOAD ROUTER DRIVERS ON LAPTOP.RICHARDM69
Posted on Dec 14, 2008
Wireless security
I think you should upgrade the firmware on your router.
After upgrading the firmware reset the router and reconfigure it manually.
I will also suggest you to create a new wireless network and use security modem WPA.
Try to connect to the new wireless network and see if that works.
See linksys router setup
Watch : How to reset Linksys router.
Jan 25, 2012 | Linksys Wireless-G Broadband Router
Internet signal is fine, works on main computer but not on laptop
download the driver here
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=19&softwareitem=dj-28354-1&lc=en&dlc=en&cc=us&lang=en&product=57565
Apr 03, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect wirelessly to my Linksys WRT160n, but wired works
Get Network Magic ... download for evaluation.
This is a tremendous network management tool well worth the $. If you dont pay, you can still use most features.
Get it and use it to get your connection going at least.
Let me know what happens
a
Oct 01, 2009 | Linksys WRT160N Wireless Router
My Dell laptop won't connect with my Linksys G wireless router
First check in your laptop wi fi switch is turn on if you have laptop.
Then check in computer that wi fi network adapter driver are installed correctly and enabled .
You can check it in my network places right click on it thne go to proeprty then you see there wi fi network driver then enable it.if disable.
Then you can see search for available networks.
If not works then post here so i give you assistanse for router configuration.
Let me know if you need more assistanse.
Aug 31, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Linksys router 160N will not work.
You probably have encryption turned on in the router, as you should... But your wireless NIC in your laptop may have the wrong settings for encryption set... Compare the two and change your NIC to match that of your router... You may have to know the passphase or password depending on your level of encryption... If by entering a valid IP by hand and it still did not work, may mean that your DNS server IP address(es) werent set correctly, you should use the router's IP address as your default gateway and primary DNS server IP address, since most likely your router is connected directly to your ISP modem... Hope this helps!!
--Joshua79
Apr 04, 2009 | Linksys WRT160N Wireless Router
Cannot connect to wireless network
To connect to the linksy's router you will need to run the linksy's setup disc on each pc in that netwrok.
Mar 29, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys Wireless not able to connect to internet
Try it with Mozilla Firefox. If it works try some searches with IE, Windows ME and wireless as search terms.
Jul 09, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Lost connection on laptop
I would reset the router most of those linksys will have a small hole in the back of them that say reset push it and let it go back to factory default see it that does not fix your prob
May 10, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT160N Wireless Router  Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
