Hi sahazada pak,
As i know, TV set not support sound from PC input.
If you want here sound and still working with PC, you should use HDMI or DVI input from your PC out. HDMI has support image and sound in one cable. DVI only image without sound. if you use DVI , sound pc should connected to audio in.
Good luck.
u cant get sound from TV linked to PC.....as the PC's sound system use a RF connection...it does not have a amplifyer...the sound system travel in two formats....non-amplified and amplified....the sound sent from PC/Laptop it's already amplified...but the TV connector can receive only non-amplified signal(say from a DVD player, camcorder, music system etc)...it cant process the signal from PC/laptop......you can connect ordinary speakers ment for laptop to the sound out jack in the PC/laptop and use the TV to receive the video signal....from PC
hope this helps
Kris
reinstall your PC's sound drivers using the drivers disk which came with the PC.
Alternatively, go to the HP website and use their automatic update service to update and reinstall your sound drivers. www.hp.com/support
If reinstalling the sound drivers fails, you may have a logic fault with your sound system, take the PC to a professional for this as this is part of the mainboard.
After PC format, you now need to put all the required pc drivers like modem driver, sound driver, LAN driver, WAN Driver, Camera Driver and other driver software. Maybe you miss this software. Check your device manager if you pc is not reading the sound card hardware because you have not install the sound card driver to activate the sound card.
The speakers may work but you probably have no sound driver. It is a sound driver that makes sound come from your pc. Type in your computers name and model on google and download drivers for your pc. If it is not drivers then your sound card is faulty.
you don't need to buy a sound card just go to your PC(brand e.g. dell,hp..etc.) website>support>enter your pc model>download your sound driver and intall.
change from windows to xp,but sound driver was not loaded/installed so there is no audio sound in my pc.from where n what driver to install in window xp for free.kindly advice n thanks.
no sound for my pc
sound isnt i need sound max for hp d2000mt
