Question about Cuisinart DCC-1200 Coffee Maker
My cuisinart coffee maker leaks
Cuisinart DCC-1200 Chrome Brew Central 12-Cup Programmable Coffeemaker. It leaks from inside when used and I want to fix it or throw the dam thing away. I have to set it on a towel to absorb the water when i want to use it. I don't find this unit particularly user friendly either---the water level indicator is not easily read, condensation on the inside of the lid from the last brew drips behind the maker onto counter when the lid is opened to make fresh coffee---if I want to add a little more water to unit to top off my cup, while unit is still on, I will get a blast of steam/ hot water in my face. not good !!??
  • fayegeo Jan 02, 2009
    I have exactly the same problem,,leaking,,is there anyway this can be fixed.
  • Rosemary
    Rosemary Jan 20, 2014
    I'm searching for a fix for these very same problems. The leaky valve is especially annoying.
1. Purchase (1) a couple of feet of 3/8" ID by 5/8" OD temperature resistant silicone tubing from a beer/wine-making supplier, or online through Ebay, and (2) a couple of hose clamps big enough for the tubing.
2. Unplug the coffee maker and turn it upside down on some old newspaper.
3. Using a T10 Torx screwdriver, remove the 4 screws that attach the the bottom plate of the coffee-maker, and remove the bottom plate.
4. Unclamp the two orange/red hoses from the C-shaped heater, and carefully pull/remove the other end of the two hoses. One hose is a water intake hose from the water tank to a C-shaped heater element, while the other hose is water outlet hose that goes from the C-shaped heater element to the sprinkler assembly.
5. Carefully remove the small plastic stop check valve from the water inlet hose end close to the C-shaped metal water heater; and take care to not drop/lose the little round plastic ball inside the plastic stop/check valve, while noting which way the stop-check valve is oriented in the hose.
6. Cut two pieces of your food-grade / temperature resistant silicone tubing that are the same length as the old hoses.
7. After reinstalling the stop-check valve in the new inlet hose/tubing, reinstall the two sections of hose/tubing, and use two hose clamps to attach the new tubing to the C-shaped water heater.
N.B. Remember that the stop check valve s/b oriented such that hot water in the C-shaped heater element can't go back to the water tank.
7. The ends of the hose that attach to the C-shaped metal water heater s/b clamped, while the other ends just push onto the water tank and sprinkler assembly with a with a little pushing and twisting.
See http://www.cocosvariety.com/2011/11/fixing-cuisinart-coffee-maker-alternate.html , as that is the original information source for this posting and the image below. i.e. Credit goes to Coco's Variety !.
Also, in the image below, the hose on the left is the water inlet hose, while the hose on the right is the water outlet hose.
Posted on Apr 18, 2012
  • 8,596 Answers
Cuisinart – leaking from bottom
There is a tube inside that is melted, damaged - cannot get this part from manufacturer. I would call Cuisinart to see if you are still in warranty.
-Tha Mp3 Doctor
Posted on Dec 15, 2008
    New Friend:
Looks like you could swap the two hoses or swap ends to put the still soft hose end on the element nipple. As stated there is a check valve however that must be removed/reinstalled or repositioned for proper flow. I used a wooden dowel to shove it through.
I found a spare piece of hose of the right type, but figure it's destined to fail as well. Unlike some others, we are only getting a few months out of these hoses, not years like some have stated. We do use it a lot though.
I intend to find a piece of flexible water line with a 3/8 id. Somebody must make a supply line in this size although you might have to chop off the connectors. That way you have "food grade" and I would assume since it can be used for hot water it is heat resistant.
Also a really clever sort could probably cut off the hard end and extend the length by installing a nipple of some sort in the center of the shortened hose.
Just some ideas, hope it helps.
Posted on Jan 07, 2013
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
My Cuisinart Brew Central Coffeemaker DCC-1200 Series has quit working? Is it under warranty?
you would have to determine if you are speaking under store credit warranty, the store will replace it with recpt usually with in 30 days, etc. or manufacture warranty if you have one it is usually 90 days maybe 1 yr. if you bought with a credit card, you have additional warranty period from visa, mastercard. check your credit card for this protection
Oct 07, 2014 | Cuisinart Dcc-1200 Brew Central 12-cup...
My7 DCC-1200 series coffee maker fail to brewe, light goes on but nothing happens
have you checked if the water filter needs to be replaced? this happened to me before and when the filter is worn water is not getting through so try to replace it. its only $5 on Amazon so worth the cost before you toss it.
Hope this helps.
Mar 19, 2013 | Cuisinart Dcc-1200 Brew Central 12-cup...
I bought a cuisinart DCC2600 as a display model. The instructions weren't available. The only thing I can't figure out is the cleaning button. How will I know when to clean the unit and exactly how do I...
The Instruction Booklet for the Cuisinart DCC-2600 Brew Central 14-Cup Programmable Coffeemaker is available here:
http://www.cuisinart.ca/pdf/ibs/en/DCC-2600C_en.pdf
See page 9 of the booklet for Cleaning and Maintenace and use of the clean button.
Mar 18, 2011 | Cuisinart Dcc-2600 14-Cup Coffee Maker
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Need instruction booklet for DCC-1200BWFR Cuisinart coffe maker?
The manual is available here:
The FR just indicates "Factory Repair" - which means it is a Refurbished item - did you buy it online, Overstock, or Big Lots?
Jul 16, 2009 | Cuisinart 12-Cup Programmable Coffeemaker...
Can one buy Cuisinart dcc 1200 coffee maker heater elements
Hello handkrobbins,
Yes, you can buy the heater elements but not from Cuisinart directly. You will need to find a small appliance repair shop to order it for you. I hope this was helpful to you. Positive feedback is appreciated. Good luck and regards, NormanZ
Jul 01, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Clean light will not off after cleaning cycle performed 4 times
Unplug the machine for 20 minutes or longer - don't skimp on the amount of time, or it won't work. After 20 minutes, plug the coffeemaker back in, and you will see that the self-clean light is now off.
Mar 29, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Leaks water out overnight
I bet it leaks from the back, right? If it does, it has the same problem as my dad's.
You have a leak in the back of the holding tank. Fill it up, turn it around, without plugging it in, and watch for the water leak. If it's in a spot that you can see, then use some caulking to seal the leak. That should work. If not, it is leaking out from inside the plastic holding tank. Not much you can do but buy a new one.
Mar 01, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart DCC-1200 Coffee Maker Logo
3,315 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
