Question about Carrier 38CKC042 Air Conditioner
Ruud Furnace needs replacement
I have a RUUD UGDA-075A-CR furnace that was made in March of 84. In the process of home improvement, I want to replace it, and I had a few people come by and size a replacement with a 70,000 btuh, 80% AFUE model.
My worry is that since theres NO information to be found on the existing furnace, I dont know if Im going smaller in output btuh, or if that even matters for the 5000 btu difference.
I just want to ensure it will be the right size. Does anyone know how efficient the old unit will be? The replacement is a goodman furnace model GMH80703AN
Thanks in advance for any help!
  • 61 Answers
What part of the country?
How many square feet in the house?
Insulation?
Single pane glass?
Many factors should be considered by a professional.
However if the old unit worked OK, a new 80% 70,000 unit will most likeley replace a 24 year old 60-70% 75,000 unit.
Posted on Dec 16, 2008
I am installing an Emerson programmable thermostat. We have a Ruud furnace achiever 90 plus that was installed 14 years ago. The thermostat mentions a power stealing switch.
The Ruud furnace is probably compatible. Power stealing is a way to recharge the thermostat battery from the 24vac control voltage used to operate the furnace. If you install the Thermostat in the "separate power supply mode" it does not need to power steal ever and will be much more reliable. Some thermostats don't get enough power in the power steal mode to keep the battery reliably recharged, especially during the cold winter months because the poiwer available to "power steal" is highest when the furnace is NOT running. You will need a separate 24 vac transformer and some wire.
Jan 06, 2018 | Ruud Heating & Cooling
I need a Ruud 80 plus gas furnace manual
Request the manual directly from Ruud.
Mar 25, 2017 | Ruud Heating & Cooling
Ruud furnace Model# UGDA-075A-CR. I would like to repair the heat Exchanger Group. Are parts available to purchase?
Im sure they are but if not done by a qualified technician you could come across some very difficult paths
Jan 05, 2017 | Ruud Heating & Cooling
Ugda-075a-cr this the correct model number for ruud furnance i have
Now how would anyone here know if that is the correct number .contact Rudd and ask them
Dec 02, 2015 | Ruud Heating & Cooling
Ruud achiever 90 plus furnace-water leaks from the drain pipe
This furnace should condense, as long as it goes into the drain. If it is leaking inside the furnace, there may be a seal that needs replacing in either the pvc drain pipe or concentric drain trap needs resealed.
Feb 21, 2015 | Ruud Heating & Cooling
My adp coil already failed in my only 2.5 yr. Old Carrier ac unit. I am now looking at an estimated $1500.00 repair. Coil is under warranty so the above cost reflects labor only. Adp serial #7107A07780....
Sorry, I don't have any solution but I'm in the process of replacing my 2 AC systems (4 tons by York). My RUUD dealer has provided RUUD ac and gas furnace with ADP coil and not using RUUD coil. Should I insist on using RUUD coil rather than ADP coil?
Thanks,
Jun 30, 2010 | Heating & Cooling
Unit three years old. came home yesterday and
Check your circuit breaker for the outdoor unit,seperate from the furnace.
Sep 09, 2009 | Ruud Heating & Cooling
Ruud Furnace Door
measure it and have any sheetmetal shop make ya one up.much cheaper than a new furnace
Nov 02, 2008 | Carrier 38CKC042 Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
378 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
