Question about Janome Memory Craft 9500 Computerized Sewing Machine
Janome Embroidery B Hoop: letters poorly done at full extension
In the last third of arm extension with the B Hoop the letters become less defined-- the stitches fewer in density. Is this hardware or Edit n' Stitch software causing this? I've run various letter font tests with software and get differing results of quality but the quality overall remains poor the closer the letters are stitched to the edge of the hoop .
dupina
  • 110 Answers
SOURCE: Husqvarna Des 1.. won't recognize hoops
The embroidery unit needs to be calibrated. Can only been done by a trained dealer. you can relax, it is not a major issue and shuold not cost you a arm and a leg. Ask the dealer to also calibrate your touch screen and download the working hours on your machine.
Regards
dupina
Posted on Dec 12, 2007
  • 185 Answers
SOURCE: 180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
Posted on Feb 25, 2008
  • 134 Answers
SOURCE: where to obtain new screw for embroidery hoop
you need to contact Janome here
http://www.janome.co.uk/contact.php
Posted on Feb 14, 2009
  • 192 Answers
SOURCE: embroidery arm won't park or go in position on hoop to embroider
You may need to have the embroidery unit serviced. The slide rods in the embroidery unit will get dirty over time and must be cleaned and lubricated. If not, the mechanism can not slide freely and you will be unable to keep the unit calibrated while stitching a design.
You could attempt to disassemble and clean it yourself, but if you bring it to a repair center in pieces or improperly assemble your repair is going to cost a lot more than it will if you go today.
Posted on Apr 20, 2009
  • 152 Answers
SOURCE: I'm using the Mega Single Hoop for the Viking
1. If the design came from the internet or a design package, it's possible that it's "center" has not been centered properly. To correct this you need to open the design in the Husqvarna Viking software and click on the "Center in Hoop" icon. That function redefines the center of the design so it will align properly in any hoop that it fits within. If you have 3d software, after clicking on that icon you physically have to put the black crosshair that designates the center in the design, in the very middle of the hoop and then save the design to your computer, then send it to the machine. The 4d software automatically centers the design in the hoop when you click on the icon.
If you have the software and you "combine" any designs together you must always click on the center design icon to recalculate or redefine the center position and then move the design's center to the middle of the hoop before saving the design. This way you center the designs center positoin around the needle position. Meaning that when you hit the start button on the machine, where ever the needle is, is where the center of your design is.
I hope this helps
Posted on Oct 15, 2009
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Feb 19, 2017 | Sewing Machines
I have the Creative Sensation and want to monogram a letter in a circle. How do I do this? Does it have to be embroidered?
You could use an applique (satin) stitch freehand on your machine. But, it takes some practice with steady hands to get it to look nice.
In the video, she uses a heat bonded stabilizer. If you don't use a bonded stabilizer, you'd want to put the fabric and stabilizer in a hoop to keep the fabric tight. If you are going to manipulate the fabric manually, you also would drop the feed dogs.
Machine Applique Tutorial
Tips for Machine Appliqu
How to Monogram with Basic Sewing Machine (in this video, she turns the fabric while stitching but to get a nice letter, you can try not turning the fabric to go around curves)
How to embroider on home sewing machine (she manually manipulates the fabric, uses a free motion quilting foot, drops the feed dogs, and uses stabilizer and a hoop)
Dec 01, 2016 | Sewing Machines
My bobbin thread is part of my embroidery on my memory craft 11000
you may have the fabric not tight enough in the hoop or try using the same colour thread in the bobbin
Nov 02, 2014 | Janome 11000 Memory Craft Special Edition...
How do I set the basting stitch length? when I try, it just beeps at me.
A BASTING STITCH IS ONLY A LONG STRAIGHT STITCH. THE NUMBER THAT IS LOWER IS A LONGER STITCH (FEWER STITCHES PER INCH). YOU WERE LIKELY MOVING YOUR NUMBER HIGHER. AFTER YOU GOT TO A CERTAIN NUMBER IT NO LONGER QUALIFIES AS A BASTING STITCH BUT A STRAIGHT STITCH. USE A LOWER NUMBER AND IT WILL LIKELY TO STOP THE BEEPING.
Sep 30, 2014 | PfaFF Sewing Machines
Why is my machine making a clicking noise when embroidering
The reason for clicking could be one of so many issues from one that could be resolved with a slight adjustment to one that needs a technician's hand. Start with where the clicking sound is amplified.
If it's louder at the top, coming from inside, it would definitely need a tech. If it's coming from the pantograph (the embroidery unit arm that holds the hoop), it could be a fraying cable (call a tech) or maybe just the hoop isn't set into the grooves properly.
If it's clicking only when the needle penetrates the fabric, check to see if the needle is damaged or dull and change it; or if the sound is evolving from further down in the bobbin area it could mean that the hook is not meeting with the needle properly and it needs to be timed (call a tech) but first check to see if maybe the bobbin's in backwards or if the needle is seated correctly.
If it happens only when you stitch one particular embroidery design, it could mean that the design is stitch intensive - lighten the density and remove unnecessary stitches.
If you switch from regular sewing to using the embroidery unit, make sure you have made all of the necessary adjustments to settings on the machine like lowering the foot feed and whatever else is required of your model (check your manual).
Bottom line, make sure you have everything threaded right, bobbin area and all thread paths clean, a new needle properly seated and all other things set right and if that doesn't solve the problem, call a tech.
Jul 31, 2014 | Brother SE400 Computerized Sewing and...
Embroidery hoop
No there should not be a lot of play.
Jan 31, 2014 | Janome Memorycraft 9700 Computerized...
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
Can i do a large applique with my pfaff 7570 using the large hoop
Both the 7560 and the 7570 will only stitch out to the largest hoop it came with which is a 120 x 115 CM hoop (approx 4 1/4 x 4 3/4 inches). If you are using the Creative Big Fantasy Hoop or a Hoop-it-All you will need to split out the design so that each piece will fit within the 120 x 115 hoop. Transfer both designs to the machine. If using the original hoop, hoop your fafabric and stitch out the 1st design. Unhoop and rehoop again aligning the fabric with the hash marks on the hoop. You will have to move the design around on the screen to make a perfect fit. Stitch out the 2nd design. If you are using the Creative Big Fantasy hoop, you just have to hoop the fabric once, stitch out the 1st design and loosen the side screw on the hoop and slide the hoop into place for the 2nd design. Stitch out the 2nd design. The same process applied to the Hoop-it-All.
livingintx@yahoo.com
Feb 28, 2013 | PfaFF Creative 7570
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
Janome Memory Craft 9500 Computerized Sewing Machine Logo
201 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
