Question about Toshiba Satellite A135-S4527 Notebook
Laptop battery thank you for your assistance.but my question is that when the battery is charged,should i displace it and use the adaptor or there is no need to disconnect it.i mean will it cause a problem if i leave the battery connected and using the adapter?
  • Eathan Dec 15, 2008
    i'm really sorry sir!i think i made a mistake choosing the ratings.please accept my apology.thank you for your assistance.it was really really helpfull!
    President:
  • 2,110 Answers
Yes it will make some problem ...As it will keep on charging even after 100%..so battery life wl decrease...so dont use charger after full charge
Posted on Dec 14, 2008
  • Sibananda Jena
    Sibananda Jena Dec 14, 2008
    I could not understand why did you gave me In Appropriate rating,,,Pls tell me ??
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
I bought a non dell battery for my inspiron 6400 note book but it wont charge,looking for a solutions,dell batteries too expensive john dublin ireland
the laptop will work with just adaptor plugged in and the battery removed.Try only adaptor plugged in.
Hoping this will work
thanks
Jan 05, 2011 | Dell Inspiron 6400 Notebook
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
ACER ASPIRE LAPTOP 2920 NO DISPLAY
Ckeck if your adaptor has power on the connector to laptop.
Might be damaged power cord (to and from the adaptor) or broken adaptor.
While there was power in the battery, it was running, but not charging.
Now the battery is emty and can't be charged because of broken adaptor/cables.
If you find there is no power from the adaptor, bepair it or buy a new one.
Do not try to repair the adaptor by yourself if you are not a technician, it is DANGEROUS !
Either give it to a qualified servicer, or betteer, buy a new one.
Regards.
Mar 27, 2009 | Computers & Internet
Power adaptor is not detected
AC Adapter Error Message Occurs
Here is what you need!!! Click on the Above Link. Follow Each and Every Step.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 22, 2009 | Dell Inspiron E1405 Notebook
Pc is telling me to plug it in when the battery is at 90%
The battery needs to be conditioned. To condition a battery, plug in the AC adaptor and charge it to 100%. Unplug the AC adaptor and run the battery completely down to 0% or until the computer shuts itself down or goes into a hibernate mode. Once this occurs, plug the AC adaptor back in and fully re-charge the battery to 100% again. You should now be good to go.
Let me know what happens and if this has solved your problem. Thank you, Binary Bob
Dec 07, 2008 | Acer Aspire 3680 Laptop
Ac adapter
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
The laptop would have to be taken apart and the DC connector resoldered.
This would cost $75 - $100. Enter your zip code in the box on the right hand side of the FixYa page to find someone close to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 17, 2008 | Dell Inspiron 1501 Notebook
Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
Oct 08, 2008 | Dell Inspiron E1705 Notebook
Does not boot up
my laptop is very slow why?
Mar 17, 2008 | Dell Latitude D600 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
