Question about Panasonic PV-C1331W 13 in. TV/VCR Combo
Audio the audio doesn't work properly after a recording. The recorded picture is fine, but the audio is the same as the previous recording.The TV/VCR plays movies just fine. We just can't record anything and play back properly. Does this have something to do with the audio head?? If you agree, what are my options?? Have checked the tracking, cleaned the head with the tape purchased at Wal-Mart. Have tried different channels and sp,lp, and slp with no luck. Think I might have got "taken" with this purchase at Ebay?? Thanks for your knowledge and experience. Have a nice day.
    Master:
  • Panasonic Master
  • 923 Answers
Does it play back professionally prerecorded tapes okay? Does that VCR have a HiFi stereo option? What is the brand name and model number of the unit?
Posted on Apr 24, 2017
2 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: Audio on recorded tape
you could try a wet type tape head cleaner but I doubt if that will help but it couldnt hurt. These combo units are built so tight together I wouldnt recomend that you try to open it. I would though look through the front door and look toward the right side and see if something got inserted into the machine and is blocking the audio head. If this dosent get you back audio then you have a curcuit problem and you are gonna need to take her in for an estimate Good Luck
Posted on May 15, 2006
Troubleshooting vcr/cable box
Seriously? You are still using a VCR?
Feb 03, 2018 | Computers & Internet
Older TV works great alone including sound. Cable TV but no box. VCR connected with cables (red,white and yellow)to TV and has worked fine. Playing home recorded VCR tape picture OK but sound is low and...
Very likely the VCR audio head is dirty which will give you muffled or low sound on play. Remove the the top cover & using a piece of non-abrasive cleaning cloth & a head cleaning fluid gently rub the audio head to clean it. The audio stack sits to the right hand side of the deck, it is usually a siler block which will be placed in front of a black roller. The head is on the side of the stack facing toward you, give this area a wipe, try a fresh recording & then replay the new recording to see if the sound has improved.
Aug 16, 2009 | Memorex Televison & Video
How can I get audio and video out from my tv if it only has audio and video in.I'm trying to connect a dvd recorder to record programs off the tv but tv does'nt have output signal.
connect dvd input cable (three banana plugs red, white, and yellow) to the video and audio output on a vcr, then take a screw on cable from the Ant. to the vcr. you will have to tune the vcr to the programs channel to record the picture. The vcr manual should tell you where the signal will be going, The picture should also go to the tv on ch 3 or 4 as when you play a vcr tape.
saddikins
Aug 05, 2009 | Televison & Video
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
Volume loss after VCR recording
Try adjusting tracking to detent Sounds like audio heads are miss aligned . Does your unit have audio levels if so turn them up when recording. Try adjusting tracking or try patching recording unit to the tv .If it has L/R video inputs use the same deck you recorded on for playback. .
Oct 24, 2017 | Toshiba 24 24 in. TV/VCR/DVD Combo
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Records media but playback has no audio.
Are you absolutely sure that it is receiving an audio signal?
What input are you using? Try recording using alternate inputs.
Audio part of a VCR is normally way more reliable than the video.
The exception is on high-end stereo types where they record the extra audio signals using the video head cylinder in which case it can easily be lost.
Jan 24, 2008 | GE VG4054 VCR
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
No sound
check your hookup of audio connections both to and from VCR. does audio input of VCR go to the proper audio out of the TV & audio out of VCR go to the correct audio input jack of TV? Your exact hookup might not be like this, but this is where to start. Some VCRs may also have an audio source switch, so check for this also. If hookup is correct, and all cabling is OK, then an internal problem is possible, and repair of such is doubtful, as most VCRs these days are disposable; repair not recommended.
Mar 23, 2007 | Panasonic PV-V4660 VHS VCR
Panasonic PV-C1331W 13 in. TV/VCR Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
