Question about Canon imageRUNNER 5000 Copier
Access of the service mode of IR 2016canon copier
Thanks for your assistance but i aam still on need to known wich command from the keys boards iam use to acess the sav mode of ir2016 canon copier.
best regards
  • lukanzu Dec 15, 2008
    thanks for your support i appreciate
  • 76 Answers
Press the following
keys to enter the service mode:
> 2 key > 8 key >
Select "#PRINT" using or , and then press the OK.
Posted on Dec 14, 2008
  • Fernan
    Fernan Dec 14, 2008
    press * 2 and 8 then # then use left and right button to select the mode
  • Alphonse Mbah
    Alphonse Mbah Sep 19, 2012
    this does not work with my C-IR2016. when I press * or # nothing respond. it take only figures like 1234567890. please help
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
1. In standby mode, press the "Settings/Registration" key.
4. Press the "Settings / Registration" key.
5. The service mode screen is displayed.
Use the "Back" key to exit Service Mode
Jan 19, 2015 | Canon Office Equipment & Supplies
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
ERROR CODE IN IR 7095 EOOO2- 0001
this error refer there is a problem in the fixing unit, check thermistor and clear that error from service mode
Apr 13, 2014 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
Ir 2880 says insert black cartridge
Hi there, please whenever i pressed *28* to enter service mode on my canon ir2200i, i got this screen that shows download mode
Please your assistance will be highly appreciated
Thank you all
Jan 24, 2014 | Canon imageRUNNER iR C2880 Color Copier
How to clear code on ir 3235?
wich code?
E000, E001, E002 You can clear under service mode:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
TURN OFF AND ON
Hope that helped
pls.rate
Apr 17, 2010 | Canon ImageRUNNER 3235 Black and White...
Eoo7
did you try a hard reset? if not please try that and get abck to us
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
E007ON IR2016(FUSER FILM OFF TRACK AND WILL NOT REPAIR ITSELF)
oh.....
the fuser film sleeve of IR 2016 and IR2200 are the same size.
please check the other reasons...
How to access the mode sav of ir 2016 canon
all differentserror code they have different way to clear out, sorry can't tell in here.
Dec 13, 2008 | Canon imageRUNNER 5000 Copier
Service mode
Hello:
All I have access to is the Toshiba Version of your machine but I think maintenance mode is the same.
This is the excerpt from the relative info in the service manual.
Example:
Basically you press # * c * ( to get into maint. mode
Press 20 Start 01 start (then the maintenance counter will clear)
I hope you can figure it out
The drum and dev counts are below
To enter the serviceman test command mode, press the keys as follows:
[#] key [*] key [C] key [*] key
To cancel the test command mode, press the [CA] key.
[10KEY]:(number pad) Entry of MAIN CODE/SUB CODE
Selection of an item
Setup of an adjustment value in case of test commands for adjustment
[/]: Selection of MAIN CODE/SUB CODE
[OK (ENTER)/START]: Settlement
<In case of test commands for print>
[OK (ENTER)]: Settlement (Without print)
[START]: Settlement/Print
[C]: (Interrupting operation check) Returns to the upper hierarchy.
In case of test command of operation check, terminates the operations.
[CA]: Exits from the test command mode.
For a test command of adjustment, the display returns to the initial display (00-00).
20 01 Maintenance counter clear (M-CNT CLR.)
24 06 Developer counter clear (DVLP CLR.)
24 07 Drum counter clear (DRUM CLR.)
Mar 12, 2008 | Sharp AR-168D Copier
Canon imageRUNNER 5000 Copier Logo
324 people viewed this question
old marine
old marine
