Question about Midland 4001 40-Channels Base CB Radio
Help me!!! hey i got a midland cb that my papa use to use but i cant talk to people on it i can hear them clear as day but they cant hear. can u help me?
  • 3 Answers
SWR OK? Is it throwing a dead-key carrier? No carrier? Midlands many times will show what looks like a processed modulation signal but is not going out your finals on the radio, and out the antenna. Suggest an external in-line meter to see if there really is a transmitted signal. If there is a signal, look for a broken/bad wire at the mics plug-in end. If no signal on the add-on meter, suspect an audio chip or final that's defective. All three are fixable at a GOOD CB Shop.
Posted on Jan 13, 2009
Im having problems with my midland 77-095 im reciving lound and clear but my output is terrible people cant hear me but i can hear them>???? thanks
it is possible you are hearing peoplein skipland. skip is an atmospheric phenomenon that causes radio waves to travel hundreds even thousands of miles. there a lot of cb operators that run high power amplifiers which would make their signal go even further. this would mean you would hear them well, but your radio doesn't have enough power to reach that person. right now we are in a solar cycle which has been causing skip daily. if you know that the peson you are trying to talk to is local and within. a few.miles then there may be an issue wit either your radio or antenna. the antenna must be tunedto the radio or you signal will not radiate off the antenna completely. over time it can destroy the radios transmit circuit. so if you have never.tuned the antenna you may be causing the radio not to work well and you may have hurt the transmit transistor.
Jun 27, 2011 | Radio Communications
Hi i have a midland 98 plus,i have been told that when i talk it have very low volume and people have to turn their set up to full volume to hear me. but the same mic on a different set works fine
Look at Radio Mods or Defcom mods. To clip modulation diode inside radio. Take to Cb shop to Peak&Tune. It may be wound to high in carrier but not audio. Buy you a "Power Mic" at Radio Shack or WWW.COPPERELECTRONICS.COM.
Apr 01, 2011 | Midland 40-Channel CB Radio CB Radio
When i talk to someone, all they hear is squealing and cannot hear what i'm saying, this is a brand new cb
Hi dm,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
Take the end of the mic. apart and check for a wire loose
touching another wire. Post back on reply.
John
Jan 31, 2011 | Midland 1001Z 40-Channels Base CB Radio
I just got my new midland CB and installed it on sunday. i can hear people however everytime i try to talk no one responds. The indicator light goes on and the rf meter goes up however i am not getting...
check the SWR. the antenna may not be tuned. Also, you may be hearing skip. If so, they are thousands of miles away, and you don't have enough power to talk to them.
Find some one close to test it.
Nov 03, 2010 | Midland 5001 40-Channels Base CB Radio
Hey my radio wont recieve when I try to talk to my friends. They can hear what I transmit but I don't get any responses back from them. Any ideas on what the problem is and how I might fix it?
Here are some things to check.
  • Try a different mic. With out a properly functioning mic, the radio will not go into receive mode.
  • Make sure the RF gain is up all the way.
  • Make sure the squelch is not too high.
  • Make sure the radio is not in PA mode and is on CB mode.
If none of the listed fixes your issue, there may be a more serious problem with the radio. It will need a tech.
Oct 07, 2010 | Midland 5001 40-Channels Base CB Radio
When I key my mic the people that I am trying to talk to only hear a sound that sounds like an air horn. Why is this?
Either the microphone is faulty, or there is a fault with the modulator. Try a new microphone or check the connections, failing that take it to a rig doctor.
May 24, 2010 | Midland 1001Z 40-Channels Base CB Radio
I've got a Midland Model-1000 CB connected to a Firestick II 3ft antenna. I can hear people loud and clear AND almost pegging the meter. I've tried to get a MIC check and I get no reply, believing the...
Could be your mic.. is it an amplified mic that has a battery in it? or a non... try replacing the mic or if it has a battery in it you probably have a dead battery that needs to be replaced..
Apr 16, 2010 | Midland 1001Z 40-Channels Base CB Radio
I need help please
Make sure you have the CTTCS codes the same on each radio! Also PMR446 radio's wont be able to talk to GMRS radio's
Aug 30, 2009 | Midland 75-822 40-Channels Handheld CB...
Midland model 1000
turn squelch all the way off , if you still get nothing you have a bad mic
Nov 21, 2008 | Midland Radio Communications
Midland 4001 40-Channels Base CB Radio Logo
141 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
