Question about Bosch Canister Compact Plus Vacuum - BSA2100 Vacuum
Vacuum hose problem
I have a Bosch BSA2100uc-02. The vacuum still works great, but the hose from the vacuum to wand handle has a hole in it. I would like to replace just the hose with plastic ends with an original one.The is about 6ft.I checked everywhere I cant seem to find one for this model. Can you help?
I took hose end off and crazy glued hose back in place.
Posted on Dec 21, 2008
Loss of suction, sucking air through hole on side of housing. Whats causing this?
The air hole on the side is a secondary air release if the suction is not reaching the dust collector detachable bucket. I had this same problem, if nothing is clogged in the hoses try scrapping all the dust off the cylindar screen filter inside the top of the detachable dust collector, I didnt realize that my filter screen had so much **** on it so I cleaned it off and the vacuum worked like a charm. Now the air can flow through unrestricted.
Mar 03, 2012 | Shark Navigator Bagless Upright Vacuum
Will not come on electrolux cannister renissance
The Renaissance and a few other models require a series of steps in troubleshooting, done in specific order, to diagnose the problem. The vacuum, hose, wands, and power nozzle need to be taken to an authorized Aerus Electrolux shop for this. The service manual is only available to the service techs, and franchise owner.
If these steps aren't followed, additional problems may result.
Things you can check include:
1. Afterfilter. This is located beneath the on-board tools. Open the access door to the tool holder by pressing latch at front of door. Squeeze clips at the front of the tray and lift to remove. If the filter is dirty, replace it. Turn vacuum on and see if it works.
2. Check for clogs in hose, wands, and power nozzle.
Disconnect hose, hold one end up, and drop a coin in. Lift end of hose so that the coin drops out. If it doesn't there's a clog that needs cleared. You may be able to do this by attaching the hose to the blower hole, placing the other end into intake and holding it there, and turning on the vacuum. If this doesn't work, it will need to be taken to the Aerus shop for clearing.
Visually check wands for a clog. A clog in the wands can be cleared with a broom stick or similar item.
Visually check the power nozzle from the bottom and the wand connection. If no clog is seen, try dropping a coin into the wand connection and seeing if it drops through. A clog here can be cleared using a wooden spoon handle or similar blunt stick.
Feb 15, 2011 | Electrolux Lux 5500 Canister Vacuum
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
Dyson DC17 Animal does not have enough suction from the wand handle to power the mini turbine head. The wand handle has very little suction.
Hi its Darran at Dyson.
It sounds as though your wand/hose assembly is blocked. Try following the blockage procedure in your user guide or visit our website's support section where you can use our self help guide to diagnose problems.
www.dyson.com
Kind regards
Darran
Dyson Customer Service
Mar 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dyson exrenable tube wont lock in
Hi there, its Darran at Dyson.
Sorry to hear of the problem that you are experiencing with your Dyson vacuum cleaner.
If you are having trouble locating the wand handle back inside the hose, it could be that the hose itself is blocked. Remove the wand handle completely from the hose, then un-clip the hose from the base of the machine to check for blockages.
To ensure you are correctly stowing the wand handle, please check your user guide or our website at www.dyson.com and visit the Support section.
Kind regards
Darran
Dec 24, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs...
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Nov 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
When hose is attached vacuum stops
there is a clog somewhere in your hose, wand or head
a plummer snake will get it or even a broom handle
Dec 28, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuum wand won't retract fully into it's compartment.
HI,
FIRSTLY DETACH WAND FROM UNIT AND SLIDE HOSE DOWN AS FAR AS IT GOES, SPRAY A LITTLE WD40 OVER WAND AND SLIDE HOSE UP AND DOWN, AS FOR THE CAP, TAKE A PAIR OF PLIARS, GRAB HOLD OF END OF CAP AND PULL CAP FULLY OUT OF THE HANDLE,AT THIS POINT CHECK THE SPRING OR REMOVE THE SPRING IF YOU PREFER AND PUSH THE CAP BACK INTO HANDLE AND THAT WILL DO IT FOR YOU.
REGARDS
DAZ
Dec 12, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Filter Queen Powerhead Not Working
is it the part where the hose connects to the wand or is where the wand connects to the power head? and what side keeps falling out. it sounds to me that its either a hose or a wand issue. unfortunatly the cord itself cannot be replaced and if the problem is a worn out connector in the hose which is possible it would require a replacement hose and if it is on the wand end it would require a new wand. either are fairly cheep on ebay. or you can possibly find one used at a local vacuum dealer. dont buy new. save yourself some money if possible.
Jul 22, 2008 | Filter Queen Majestic Canister Vacuum
Bosch Canister Compact Plus Vacuum - BSA2100 Vacuum Logo
140 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
