Question about Hotpoint RVM1435 Microwave Oven
We turned our microwave on for a two minute heating cycle. After about 60 seconds, the whole microwave shut down, including the display. We have plugged other appliances into that outlet to verify that the outlet is in working order, which it is. Any ideas?
  • 38 Answers
The fuse inside microwave is blown. It may have been from magnetron or door switch. Not a real good do-it yourself job. (high voltage).
Posted on Mar 09, 2009
I have a Sharp R1870 micro/convection unit. unit kicks off after 60 seconds. have to restart then kicks off again in 60 seconds.
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
I have the applicable service manuals for these models and have uploaded it to my site here and here to help you.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 04, 2017 | Sharp Microwave Ovens
Ge pvm2070smss shuts down
It may be a noisy magnetron if the failure occurs in a second or two of hitting "Start" to begin cooking.
See this FixYa solution. even though your model number is different.
Otherwise, if the internal cooling fan is not running when you are cooking, it will shut down after 30-60 seconds or so and stay off until it cools back down.
Also see http://www.microwavedisplay.com/jvm2070.htm
Feb 24, 2013 | GE PVM2070SMSS Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
Sep 25, 2009 | Hotpoint RVM1435 Microwave Oven
Oven shuts down after a few seconds into cycle time for cooking
The magnatron (heating element) is located in the cavity behind the control. If it's leaking microwaves onto the electronics, this will occur. This means the Mag should be replaced and a radiation test run on unit.
Mar 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave heats but shuts off due to the fan not coming on
A little late for a reply; you probably have replaced it by now.
I suspect it shuts down because the fan is no longer turning on and there is probably a thermal shutoff switch near or on the magnetron to prevent the chance of fire.
Jan 08, 2008 | GE JVM1190 Microwave Oven
Magic Chef MCO153UW
The cooling fan is a must!
Otherwise, the magnetron will be ruined, and that drives up the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order parts here: https://www.mcappliance.com/partorder.aspx
To contact Magic Chef about getting an *authorized* servicer, see: http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | Magic Chef CMV1000B Microwave Oven
Maytag MMV5165BA Over The Range Microwave
We had this problem. It was installed improperly - to recirculate instead of to vent.
Sep 07, 2007 | Westinghouse WST3504 Microwave Oven
Hotpoint RVM1435 Microwave Oven Logo
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
