Convergence problem with projection TV
I have an Akai Model PT 4799 HD television that seems to have a convergence problem.  The "No Signal" screen is "ghosting" red and I cannot get it into focus.  Any idea what I can do to fix this?
  • rabbit7971 Jan 05, 2009
    Would this problem require a TV Technician? If so, where is the closest certified repair shop or dealer? I am located in central Kentucky about 20 minutes East of Lexington.
  • 19,396 Answers
As explained you need a technician to fix the problem.
If the unit is under warranty you need to contact akai, and they only deal by email, see website here : Thank You for contacting the akai Customer Care Website.
If warranty is expired (one year) then repair at the nearest akai authorized repairer, in Lexington try Bobby Jones & Son TV. at (859) 246-0107 .
Posted on Jan 05, 2009
    Sergeant:
    Scholar:
  • 199 Answers
For the technician at your place there is a column on the fixya main home page named-------repair/service.just enter your exact zip code in that column.and select the appropriate unit to be repaired for example tv.and check out .the list of certified engineer near to your area will be displayed with telephone numbers and company profile.u can directly call them at your place to get it repaired. for any thing else let me know. thanks.
  • 679 Answers
Go for service info. site:
http://www.ercservice.com/Express/Plasma.html
Thanks for using FixYa.
  • rockfixya
    rockfixya Jan 07, 2009
    did you see the given link?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the ghosting effect and the no focus both indicates a convergence issue. While technically this requires the replacement of only 2 ICS, a couple of resistors and possibly pico fuses, it is a challenging DIY (do-it-yourself) repair if not familiar with electronic components & circuitry, use of a DVD and a soldering iron. As the others have posted, perhaps your best bet would then be to seek the services of a qualified professional.
Additionally, the final alignment after the repairs wouold be very exacting better left off to experienced hands.
Good luck and Thank you for using FixYa.
    Sergeant:
    Novelist:
  • 326 Answers
As you said its the convergence proble,so there is a convergence stk ic on the main board of the tv which mostly goes faulty and needs replacement to make it proper.as to replace it you will need a technician at your place to replace that ic from the main board.a local tv repair technician is much advisable as certified technician can charge more srervice charge for this job.
it will get repaired.as i would suggest worth repaing it.
    Genius:
  • 1,913 Answers
Resset your projection to factorty dafults settings.
also change resolution .connect it with computer then check .
  • 3,037 Answers
Hello rabbit7971
This is a failure of the convergence amp's - not a job for self-repair. normal repair for PTV sets with this problem should run $250-$350. Call a local repairman for repair don't go through the manufacturer, their $300 ISC alignment service is a total crock, 99% of sets cannot be set to anything close to a "PRO" standard - you will not see the change anyway & first time you move the tint or contrast the setting is lost anyway.
BTW do NOT move the crt lens assembly at all, if you have a 1 hour job just turned into several hours of alignment for the tech -at your expense
good luck and let me know if you have any more questions
bestdarngood
Posted on Dec 31, 2008
    Sergeant:
    Champion:
  • 304 Answers
If you have no idea or experience servicing tv. it is better to contact a repairman to do the work for you..
it's too dangerous for someone who is not familiar repairing the unit.,
I have an Akai 42"
Its usually the convergence board just replacing the old board with a good one should solve the issue. You can get the convergence board for the PT4298 at the following link just scroll down the page. http://www.tvrepairworld.com/samsung__akai_circuit_boards
Jun 24, 2011 | Akai PT4298HD Rear Projection Television
When text appears on screen, the letters overlap on R/L sides
Ur tv have a convergence problems,the 2 STK convergence ICS are defective.Try website like Tv repair World.com.They sell the rebuild Akai/Samsung the whole convergence board.They used the same convergence board.
May 07, 2010 | Akai PT4298HD Rear Projection Television
I have an akai 50 inch tv. I have a darker area on the left side of the screen about 3 inches wide. I replaced the bulb but the problem is still there. Any idea how to fix it. Its a projection tv.
Convergence is dead.Replaced the 2 convergence ICS,should solved this problems.Try website Tv repair World.com to buy a Whole convergence board to replaced.Samsung/Akai use the same convergence board.
Feb 26, 2010 | Akai PT4298HD Rear Projection Television
My Akai TV Model number PT5598HD shows two of everything, how do I fix this?
U can't.Ur convergence is dead.Try website Tv repair World.com to buy a Convergence board to replaced.Well solved the convergence problems.The Samsung/Akai use the same convergence board.
Feb 15, 2010 | Akai PT5598HD 55" Rear Projection...
My 2005 WD62725 just started getting wavy lines on it. Everything works good (i have picture and sound and all functions) but the lines started first only when a non-HD signal was coming in. Now it has...
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Where can i get a convergence chip for PT4799HD akai tv?
I'm fairly certain that particular Akai model contains Samsung parts. You can contact Samsung at 1-800-726-7864 to check pricing and availability of the part you seek.
Jul 12, 2009 | Akai PT4799HD Rear Projection Television
Convergence Problem
Replace the Convergence Ics and the six 2.2 ohm resistors. Heres a link to the proper repair kit for your model which contains both Ics and the resistors plus step by step instructions with pics on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
May 06, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Problem with HD feed from satellite receiver
I just had my HD DTV installed this weekend, you have to leave it on 480p. I too purchased my tv in 2002. Per DTV, its an older model and you have to stay with the 480p to get the best possible picture. I have to admit, don't know what the 1080i looks like, but 480p is showing me a very good picture. Best I have ever seen on my TV.
Jun 27, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Convergence Problem
I'm not a 100% positive this would fix your TV, but I found the convergence board on PartStore.com for about $80. Hope this helps.
Nov 16, 2007 | Akai PT5598HD 55" Rear Projection...
PT5499HD Covergence Akai
Yes, you have a size problem you have horizontal and vertical size. Either its' in the service mode or somewhere on the set, with this set it's probably in menu. Must be set too high. I will look for menu codes! Is this an Akai or Panasonic set?
Oct 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
