Question about Samsung LE40R74BDX 40 in. LCD Television
Marks on screen
There is a few mark on the bottom of the tv screen how could i remove them
If its just dirty marks use a solution of 50% deionised water and 50% isopropyl alcohol. Use a lint free cloth and it should lift the marks. Any household polish etc may react with the LCD surface and burn it. If you cant get hold of isopopyl go for branded cleaning kits for LCD TV screens. You'll get these in most electrical stores.
Posted on Dec 16, 2008
57wv600 blinks 7 times, no picture, or blue for few seconds
1. Remove the 5 screws from behind each speaker
2. Grasp bottom center of plastic panel and "pop" forward. Swing upward to remove.
3. Remove 4 screws from the wooden panel in center.
4. There is a "black box" in the very front of electronics. It will have torque paint on the 2 rows of 3 screws. top row is labeled "focus"
MY TV would go green before going black. Volume still worked.
5. I turned the center bottom screw (marked "green") appx. 1/8 to 1/4 turn COUNTER clockwise.
Plugged TV in and it works fine.
Oct 08, 2011 | Sony KP-57WV600 57" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Apex Digital TV Model: 1919. Worked fine for a
Power supply issues or shorted horizontal output transistor. Probably not worth having repaired unless you DIY....
May 17, 2009 | Apex Digital LD1919 19 in. LCD TV
Sony, tv comes on color fine, then turns red
I had the same problem with my TV, but the hue was blue. I was told that not only did I have to replace the picture tube that wasn't staying on, but I would have to replace them all because they would not mix properly. After much investigation, I found that there is an adjustment for a variable power supply to each tube that can brighten and lighten each tube. I adjusted the RED pot and my picture color issue was resolved! To access this adjustment you must remove the front panel on the TV. At the bottom corners there are two small screw covers that you must remove. Then un-screw the screws under the covers. Then pull the front panel off of the TV, (it hooks under the top near the screen so it will swing out from the bottom). Now remove the wooden panel in the center, (four screws). The pot adjustments are at the bottom of the TV. They are marked for Red, Blue, and Green. They are extremely sensitive, don't turn them much! If you over adjust you will get red, green, or blue lines on your screen. Adjust back down to remove these, (this is also the remedy for removing these lines that can appear over time). Good Luck and God Bless!
Mar 17, 2009 | Sony KP-51HW40 51" Rear Projection...
the timming marks will be behind the timing belt cover. There will be marks on the gears and also marks on the block. Line the top gear with the top mark and the bottom gear with the bottom mark. Please note that you will need to undo the battery for a few minutes and then reconnect. This allows the computer to reset itself. Hope this helps
Mar 06, 2009 | 1987 Ford Escort
Hitachi 57inch tv 4 years old has a black mark on the screen
Thanks for your reply. The only thing that causes marks like that is usually the glue that holds the lenticular screen and the fresnal lens together heats up and drips (or slides) down. There is usually a strip of black tape that seals the two pieces of thin, glass sheets. This allows for easier installation and keeps debris from getting between screen and lens, however, someone overlooked the elements of heat and aging on this tape.The screen and lens can either be replaced or disassembled and cleaned. They are very expensive, (a few hundred dollars each), and disassembly can be very tedious. One caution I must give you is to make sure if you seperate the screen and lens make sure they go back together facing the same way. Try to clean only with warm water and a few drops of a very mild cleanser like dawn. If all else fails, you can buy a used screen sometimes from a local factory authorized service center. Occasionally they save the ones that are in decent shape. I have one 57" screen here in cincinnati that would work. Good luck, Russmann.
Jan 09, 2009 | Hitachi 57F500 57" Rear Projection...
New lcd tv with a crack like mark on the bottom of the screen
Hello. If the panel is cracked (the glass of the LCD), the by all means, return it as soon as possible. I've seen quite a few LCD's with cracked panels, and they all came from shipping from the factory.
The easiest way to tell is if you can see it when the television is off. If you can, it is in the panel itself. Sometimes you have to look with a flashlight to tell, but it should be present.
Dec 29, 2008 | Samsung (LTR268W) Television
45" mitsubishi TV with gray/black "water stains" on screen
If the plastic screen has not been damaged by chemical properties in the liquids, the screen does not separate. Time will tell.
Apr 04, 2017 | Televison & Video
Half the screen has gone black
Ok first lets start with the half screen and no lit screen . Samsung plasma panels (S42AX-YD01) HD V4. are really bad about the Y-board (upper,lower) buffers are really bad about getting hot and burining up. If u remove the back cover of TV u will see on the left side the Y-board (it will be marked in small letters) if u look and the rows of IC's with heatsinks on the buffers will be a dark yellow. Majority of the time if u remove the buffers. and look underneath them u will see the solder has melted from the board. U can replace the Y-board and buffers and the TV will work fine.
Next part if u have vertical lines in the panel. There is not much u can do as a repair. Only thing u can do is get panel replaced. because there is and IC that is burned up on the panel, and trust me there isn't anything u can do to fix it. If u want to see for yourself. After removing the back cover, remove SSB, and brackets holding PDP in place. at the bottom of TV there is a row of buffers marked E,F,G, ( i think) there is a long heat sink covering the IC's at the bottom connected to the bottom of PDP. As u can see without a $70k machine to change this there is not much u can do with it. Hope this helps.
Dec 22, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Samsung LE40R74BDX 40 in. LCD Television Logo
133 people viewed this question
Jerry Greenberg
Jerry Greenberg
