Paper jammed in Lexmark 730
A few sheets of paper have gone into the printer al at once and they are jammed.
My daughter sorted it out.
Posted on Dec 15, 2008
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
LexMark 5400 Series All-In-One Printer
To clear a paper jam:
  • Pull Carefully
    If the sheet of paper is visible at the output slot of the printer (in other word, it stopped on its way out of the printer), try pulling carefully on it. If it pulls smoothly and easily, then carefully pull it the rest of the way out. If there is resistance, then stop and go on to the next step.
  • Open the Cover
    Open the printer cover and wait (in the case of an inkjet printer) for the carriage to stop moving. Carefully, slowly pull out any paper that is caught there.
  • Take Care
    Do NOT pull paper out from where it was feeding into the printer (where the blank paper enters the device). The rollers on your printer may only go in one direction, and if you force them the wrong way, you could damage the machine.
Be careful of the following:
  • Laser Printers
    If you have a laser printer, be very careful when pulling out the paper -- laser printers can get hot.
  • Paper Shreds
    If any paper tore, either during the jam or while you were removing them, remove any appliances that you can (paper trays, etc.) and look for the shreds of paper. Try to make sure nothing has been left behind.
If you have frequent paper jams:
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
Goodluck..
Feb 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Where is the paper jam when the panel of our Lexmark C750 says "200 paper jam"
Primary: Paper is jammed at the printer input sensor. Open the printer left door to access the paper jam. If sheets have been accumulated to be stapled or offset when the jam occurred, the printer alternately flashes the primary and secondary messages to indicate that all accumulated sheets not be removed during the jam clearing procedure.
Secondary: When this message is displayed, do not remove accumulated sheets during the jam clearing procedure as the printer will not reprint the removed sheets. Also, if the accumulated sheets are removed, the portion of the job printed after the jam will not be stapled.
Nov 03, 2009 | Lexmark C750 Laser Printer
Paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
May 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Roller drags several sheets of paper and results in a paper jam
Open your printer and release jam paper then solve problem.
Apr 09, 2009 | Lexmark E322 Laser Printer
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
SCX-4200 jam
remove the toner box then clean the black colour roller with a wet smooth cloth.
May 05, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam error
print_friendly.gif null.gif null.gif null.gif null.gif How to Resolve Paper Jams ID:894 null.gif null.gif null.gif
If the paper is lodged too far into the printer and can't be removed:
  1. Press the power button to turn the printer off.
  2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
  3. Close the front cover.
  4. Press the power button to turn the printer back on.
  5. Resend your document to print.
Ensure that:
  • The paper is a recommended paper for inkjet printers.
  • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
  • The printer is on a flat, level surface.
  • The left paper guide is against the side of the paper.
  • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
  • The left paper guide does not cause the paper to bend in the sheet feeder.
  • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
  • Envelopes or the appropriate specialty papers are selected in the printer driver.
  • You are using a paper or envelope size supported by your printer.
Important: Your application may not be designed to print envelopes. For help, consult the documentation that accompanied your application.
Apr 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
Paper jams
Check solinoid transformers that controls opening and closing of paper handling trays. Check and clean sensors from in and out of paper path. Check and clean paper rollers or heat rollers for dust and paper remains pieces. Please determine when is the paper jams occurs. Hope this gives you hints.
Best regards,
Rosener
Feb 05, 2008 | Lexmark E238 Laser Printer
Lexmark X83 all-in-one printer
Hi gerby, need to eliminate a few issues to get to the cause. First, check for a jam. Paper jams can be so tiny you can barely notice them. Use a torch and check thoroughly down back of unit in paper feeder, open cover, let cartridge carriage roll left and settle. Now look inside thoroughly too. If no jam, check rollers are even and look same on each side. Post back if no good.
Sep 01, 2007 | Lexmark X83 All-In-One InkJet Printer
k24674
jasbo
jasbo
