Question about Grilling
Generator with natural gas conversion intermittently sputters
I converted my generator to natural gas using a type C conversion kit. Generator ran fine the first few times I needed it. Lately, it been difficult to start. After priming it starts but stops. After several repeats is runs then goes to stop then kicks in again. Eventually its somewhat stable. But still occasionally misses and occasionally almost dies but kick in again. I do not the exhaust pipe does glow red when it gets dark.
    Top Expert:
  • 46,506 Answers
Running out of time and too rich
suggest that you call in an auto gas technician to check and adjust the regulator /converter for the gas to get it running right
Posted on Jul 03, 2017
SOURCE: how to convert from lp to ng
Yes,
I converted a Sam's Club Members Mark grille last year and just did some research on the internet and found a numbered drill size chart that gave me the correct drill size to use on each burner(side,main and rear)for the proper BTU supply for the size or BTU rating for your burner. I drilled them, All has worked well! I know Ducane will tell you not to do that, but I think it is a legal issue. If you have a problem, they don't to get a letter from your lawyer.
Posted on May 13, 2008
freetek
  • 5568 Answers
SOURCE: Want to convert from LP to Natural Gas
Typically, the only thing required is changing any and all jets since energy content and pressure are different. The only source for these is probably the manufacturer; check their website.
Posted on May 20, 2009
SOURCE: jenn air propane grill conversion
It is inconceivable to me that large manufacturers like Jenn-Air and Nexgrill can jointly make and sell an expensive grill and then completely abandon the consumer. I purchased an Jenn-Air 740-0142 LPG and like so many wanted to convert to nautural gas which requires a larger gas orifice. I spent a month on the internet and phone calling Jenn-Air and finally Nexgrill who actually manufactured the unit in China. The Jenn-Air and Nexgrill serial numbers are the same. the 740 prefix is LPG and the 750 prefix is natural gas. After three calls to Nexgrill I found a manager who actually acknowledged making Jenn-Air but declined selling me parts for it as I believe they have product liability concerns. I call back as a Nexgrill owner and finally ordered natural gas orifices at $10.00 each. The shipment never showed up. Calling back again I was told that they really didnt really have any orifices in stock but could sell me the entire replacement gas valve for $28.00 which I purchased. The valves actually arrived on the shipping receipt was from The Grill Services in City of Industry 909-718-6128 www.grillservices.com . Part number 750-0141/142/593/594.
Forget about pirates in Somalia... we have them right here. Shame on you Jenn-Air and Nextgrill.
Posted on May 31, 2009
  • 512 Answers
SOURCE: Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
Posted on Jan 20, 2010
SOURCE: Conversion kit for Weber Summit LP to Natural Gas
You can buy a conversion kit for $150.00 from the Weber Parts center. However you don’t need to purchase a conversion kit. You can drill out the Brass Orifices with a 1/16 drill bit you should be good up to 15,000 BTU. You do need a Natural Gas hose/regulator. After that you should be good to go!
Posted on Jul 06, 2010
How reliable is patriot Power Generator?
Best to look for reviews on websites of companies that sell particular brands. Regardless of brand, make sure to drain fuel completely after use. Most small engine equipment, including generators, are not ethanol friendly, so use Pure Gas if available in your area. I recommend you look for a tri-fuel model that will run on gasoline, natural gas, or propane. Also, there are kits available to convert gas generator to tri-fuel or bi-fuel.
https://www.pure-gas.org/
Generator Conversion Kits to Propane and Natural Gas
Jun 18, 2017 | Miscellaneous
Generator is two yrs old only had a couple of outages maybe totaling thirty hrs Generator ran great and also ran every wk for its exerciser cycle. The generator didn't start on this cycle and the system...
Is this a natural gas fueled generator? Sounds like a fuel problem, i would go through the fuel system and find out whats wrong. If its a natural gas/propane unit its most likely a bad regulator or low pressure.
May 04, 2017 | Eaton Electrical Supplies
Generator w/nat gas conversion kit sputters
THAT SOUNDS like a VERY LEAN condition. The exhause glowing is because its so lean. The stalling the sputtering. OPEN the gas valve more WHILE its running. With a load if possible.. If you have a tri fuel kit like I do, going from propane to nat gas I need to open the load block (gas valve) 2 turns more .Then it starts and runs great.
Jul 27, 2012 | Electrical Supplies
Do they make a conversion kit from NG to LP for a Ducane Meridian 32" grill ???....btw, the model has been discontinued.
Unfortunately, there is not a conversion kit available to convert a Ducane/Webber Grill from one gas type to another. In fact, there never has been, to the best of my knowledge.
The reason for this is that each model is tested and approved for a specific gas type. Whether it's Natural Gas or Propane Gas. Attempts to convert them from one gas type to another would then place all the liability on you, if something should go wrong, because of the conversion. Even the Owner's Manual states that.
My best advice, is clean the grill up and sell it to someone who wants a Natural Gas Grill. Use that money to put toward a new LP Gas Grill. That's the safest way to do it.
I hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Ducane Meridian MDBQ-30 Grill
Need to convert our Q300 propane grill to natural gas. Do you sell conversion kits?
Unfortunately, Weber grills are not convertible from one gas type to another. There are no conversion kits available for your model or any Weber model gas grill.
To confirm this, go to the following link and on page 2 under Warnings, last paragraph, left hand column, you can confirm this, if you like.
http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/Q300320_OwnersGuide_41060_021011.pdf
The only advantage to converting it to Natural Gas is not having to refill the grill tank. The downside, is that you will loose the heating capability that Propane has. It burns cleaner and hotter than Natural gas, in an outdoor environment.
Hope this helped you. Happy Grilling!!
Jul 13, 2011 | Weber Q300 Grill
I have a grill Frigidaire FD27LKEC 27 it is running with natural gas and I would like to convert it to propan. Is there a convertion kit or what do I need to change.
At one time, there was a conversion kit available to convert your model from Natural Gas to Propane Gas. Unfortunately, it is no longer available and has been removed from the retail market. This, usually happens, when a problem resulted from a conversion of one gas type to another.
May 23, 2011 | Frigidaire FD27LKEC (LP) Grill
I have a Turbo Elite 3 burner barbecue. Want to convert it from propane to natural gas. Where can I get a conversion kit?
Your best bet is BBQ's Galore. Since it's their grill, if there is a conversion kit for that model, they'll have it. However, not all gas grills are convertible from one gas type to another.
Apr 01, 2011 | Grilling
Conversion of yamaha gasoline generaor into natural gas...
i know YAMAHAwere doingsome work on converting outboard motors to run on LPG they may be able to get a bit of info from the STATE distributors might be worth a phone call
Jul 20, 2009 | Electrical Supplies
Conversion of Yamaha gasoline electricazl generator engine to natural gas
My answer:
Hello Bill:
Here are the site links you'll need to check and/or get info, or buy your adapter kit for your Yami YG4600D Genset conversion kit.
Most likely it's running an 8 or 10HP engine on it now? In any case it's most likely less then 12HP. Not sure what size engine you have, as you didn't say only for the model #? On older Gensets it's harder to track down the HP rated engine is all.
For your Yami YG4600D Genset there you most likely will have your choice of at least 4 adapter kits depending on if you are going to keep gasoline as an option. If you're definitely NOT going to be ever running gasoline again then there are 1 or 2 adapter kits to choose from.
Use the site links below, and then browse whichever area you want as there are many options there. The last link listed takes you through all the different engines by make & model #'s.
I would also shop around locally where you are in LA, as you might be able to get that adapter kit for a lot less then the $227 to $267 they are asking for there at that site.
If you don't see your exact model # (or kit) there call them on their 800 toll free # listed at their site.
Also - if this site doesn't meet your expectations customer service wise at least you will have a starting off point with the wealth of information supplied there!
http://www.propane-generators.com/what_kit_do_i_need.htm
"What Kit Do I Need?"
http://www.propane-generators.com/simple_explanation.htm
"Simple Explanation"
http://www.propane-generators.com/a-c_kit_list.htm
A and C Kit List
Please post me a reply as to this info helping you solve your adapter kit problem there by following my posting recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Sep 06, 2008 | Yamaha Electrical Supplies
Grilling Logo
130 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
