I can see the battery but I don't see any latch to release it.
SOURCE: HP Pavilion dv2120us Notebook PC battery release latch
My battery latch got stuck in the open position after replacing the battery on HP's DV 6300 series. The battery was thus stuck. I used the 'screwdriver' technique but with a rounded end kitchen knife not an actual screwdriver to remove the battery. It is important to push the knife down a little into the groove at the outer long edge of the battery and pry that outer edge up. AFTER DOING THIS THEN GOING TO REPLACE THE BATTERY I REALIZED THE LATCH PROBLEM OCCURRED BECAUSE I HAD PUSHED THE BATTERY LATCH TO THE OPEN POSITION TO REPLACE THE BATTERY. THIS IS WHAT JAMS IT. TO REPLACE THE BATTERY 'DON'T TOUCH THE LATCH AT ALL'. LEAVE THE LATCH IN THE CLOSED POSITION AND REPLACING THE BATTERY WILL SET THE LATCH IN THE CORRECT CLOSED POSITION, READY TO BE SLID TO OPEN POSITION ONLY TO DO THE ACTUAL BATTERY REMOVAL.
SOURCE: I have this problem with
Remove accumulator too. Firstly accu then RTC battery and before this power supply. You need to put your laptop to no power for about 5-10 min
SOURCE: Forgot Power ON Password HP Compaq nx7300
unplug the power supply remove the laptop battery then locate your bios battery and disconect it next wait abouy 15 minutes plug in the bios battry then connect the power supply turn on your computer turn off your computer then put in your battery start up your computer and your passwords should be reset
SOURCE: need to replace RTC battery in dv7-1240 hp
Battery is usually located on bottom of laptop usually takes 1-4 screws to get it out.
There are usually 2 compartments on the bottom, one for RAM memory upgrades and the other compartment is the battery.
