Car Audio & Video Logo
Sarah Henson Posted on Jul 27, 2012
I just bought a 2001 Subaru Forester, I put the key in the door lock to unlock the door and the alarm went off and won't stop. How do I turn the alarm off?
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jul 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
667
Points
12
I would try to close the door and press the unlock button on the kay fob. (If it has a remote intergrated with the key). This should unlock the door and turn off any anti-theft devices.
1helpful
3answers
How to stop blinking parking lights on a subaru forester after disconnecting the battery
Changed battery now running lights flash 2000 Forester Quick fix on mine use remote key fob lock door then unlock everything good no more flashing.
My car alarm went off now car won't start.security light flashes on dash.I HAVE a 2001 GMC jimmy
Try putting the key in the driver's door and locking/unlocking it. This will often reset the onboard security.
Hope this helps
2answers
How do I turn off the door alarm on my 2002 Chrysler PT? When I put the key in and unlock the door, the alarm goes off and doesn't stop until I turn the ignition on.
this is a standard warning to tell you the keys are in the ignition to help prevent them from being locked inside. This is a factory alarm and cannot be turned off
2answers
Subaru Forester 2001. Parking lights stay on when car is turned off. Lights go off only when fuse removed. Light switch on steering column was changed to no effect. Separately, AC, fan and heater...
I have had the parking lights on my 1998 forester stay on w/ no way to turn off. Used the remote door lock to lock and unlock car and the lights went off?????????? This has happened twice with the same solution
2answers
HELP please!! My daughter has a 96 sebring convertible and today she put her key in the door to unlock it and the alarm started going off. It wont stop, have disconnected the positive and negative battery...
Just a quick note once you hook the battery back up try locking it and unlocking it from the drivers door, if that fails you might try the passenger door. I know on some chrysler products you have to lock and lock again to arm and unlock to disarm. I hope this helps.
Thanks,
Joey
1helpful
I bought a new Keyless remote for a 2007 Forester from a Subaru Dealer to replace an original one that went bad after 2 years. I have followed the directions in the owner's manual to program it, but can't...
IMPREZA: 2005, 2006, 2007 and
FORESTER: 2005, 2006, 2007, 2008
Check for Immobilizer key on Forester XT models only.
information is always subject to change and correction imp05keylessremote1.jpg
new remote for 2005 Imprezas.
This is not the same remote as the 05 Legacy/Outback remote which also has truck/gate release on the front and a red panic button on the back.
Lock: press Lock button for 2 seconds or so to lock car, and arm optional security system. The car with chirp once and turn signals flash for locked, 5 short chirps and signal flashes if any door is not fully closed. The dome light goes on for 15 seconds and ignition key ring (if present) will light for 30 seconds when unlocked.
Unlock: press unlock one time for driver's door, press again within 5 seconds to unlock all doors inkling rear gate (wagon). The system does not open the trunk.
Panic mode: press and hold lock button for approx. 3-4 seconds to activate Panic mode. I panic model the horn honks and turn signals flash until either the lock or unlock button is pushed again.
Finder mode: Press lock button 3 times within 5 seconds to activate Vehicle Finder mode. The horn will honk once and the turn signals will flash 3 times
Distance: works within approx. 30 feet depending on battery strength, nearby concrete walls and etc.
Audible Chirp On-Off: the system will chirp when locked or unlocked. To turn OFF the chirps, unlock the door and then push both lock and unlock buttons at the exact same time for 2+ seconds. There will be 2 chirps indicating the the audible is off. To turn the chirp back on, repeat the process and the system will chirp one time when it is back on.
Battery: as the battery ages it will only work as you get closer to the car. When a battery is replaced, the transmitter must be re-synchronized with the Keyless control unit. To synchronize, press the lock or unlock button 6 times.
Programming: 4 codes may be programmed.
Sit in driver's seat and unlock all doors. Open and close the driver's door
Turn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.
You now have 45 seconds to complete the programming as below.
Open and close driver's door again.
Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.
To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.
Done programming? remove the key from the ignition and the horn will honk 3 times.
DELETE old codes? Reprogram 4 times, it will overwrite old codes.
Alarm Security System: optional on all models. When locked there is one chirp (can be turned off, see above), the turn signals will flash and the red 'security' light will start to flash once every 2 seconds except for STi which flashes twice every 2 seconds.
There will be 5 chirps if a door, hood, and trunk or gate is not fully closed
You can also arm the system by using the power lock button on the driver or passenger door as you get out of the car and then closing the door behind you.
Disarm the system: push unlock for 2 seconds
Lost remote, alarm activated? When you can't use a remote to turn off the system: open the door with a key or try to start the car and the horn will start to honk. Turn the key on-off 3 times within 5 seconds and the alarm will go off and you can start the car. It's simple!
VALET mode: To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds. The red 'security' light will then flash 2 times a second until the car is turned on.
System has been Tripped (except for STi): if you unlock the door with the remote and it chirps the signal light flash 4 times, the system has been triggered;
Identification mode: To find out what happened and why the system was triggered:
Open and drivers door, leave it open. Turn ignition key from LOCK to ON 2 times and then leave in LOCK position.
Tripped code: 1 security light flash: a door has been opened, 3 flashes when the impact sensor was triggered, 4 flashes when the ignition was messed with or battery disconnected
1helpful
2001 subaru impreza WRX unlocking doors with key
usually after opening the door you can deactivate the alarm by pushing th unlock button or simply insert keyy in ignition and turn it on.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
