Question about Intel DG965RY Motherboard
DG965RY boot problem
Thank you "The only-sol" for going through my problem.
Well, my Mobo is Intel DG965RY which has 4 DIMM slots, two of which are Slot A and other two are slot B. So my mobo does support more than 3 DDR2. Intel recommends to fill up both channels (0 and 1) of Slot A first and then go for slot B. I have 3 nos. of 512MB DDR2. So I fill up both channels of Slot A and then installed one 512MB DDR2 in Slot B channel 0. All DDR2 RAM are of same spec. However, during cold boot, if I press the start button immediately after POST procedure, there is beep sounds indicating some kind of error and there is no display. However if I allow some 10 seconds after POST, then the computer boots.
The other problem is I can not restart my computer. It simply whizzes and buzzes with CPU fan running at top speed but it simply does not reboot even though there seem to be lots of processing going on.
Really strange problem. Maybe designer of this Mobo can throw some light on it. Thanks in advance.
  • 41 Answers
Hi niraj73
1. Remove the 1 Ram module from Slot B Channel 0.
2. See if problem is still there.
3. If not get another Ram module of same spec to fill up all 4 channels.
4 If error still there swap the removed Ram module with one of the Ram modules still installed. One of them might be faulty.
Regards
Go-Tech
Posted on Dec 14, 2008
E8 Error
Hello here is the homepage:
http://www.asrock.com/mb/Intel/X58%20Extreme6/?cat=Manual
I think you have a ram problem:
1. Please install the memory module into the white slot (DDR3_A1,
DDR3_B1 or DDR3_C1) for the first priority.
2. Due to Intel CPU spec definition, the system will not boot if only
one DIMM is installed into DDR3_A2, DDR3_B2 or DDR3_C2 slot.
3. Due to Intel CPU spec definition, XMP DIMMs and DDR3 2000/
1866/1600 are supported for one DIMM per channel only.
4. You may install varying memory sizes in Channel A, Channel B and
Channel C. The system maps the total size of the lower-sized
channel for the dual-channel or triple-channel configuration. Any
excess memory from the higher-sized channel is then mapped for
single-channel operation.
5. It is not allowed to install a DDR or DDR2 memory module into
DDR3 slot; otherwise, this motherboard and DIMM may be
damaged.
Try only with one module, in the white slot.
Hope this will help you.
Jan 30, 2013 | Asrock X58 EXTREME6 LGA 1366 Intel X58...
Asrock g31 m motherboard will only post if only one ram slot occupied , will not post if both slots are used , identical matched pair of ram ddr 667 800 mhz crucial ballistix both tested in another ri
I did some research. You didn't say what density the RAM was, but everything I can find on the Ballistix 800 MHZ DDR2 states that it runs at 2.2V. The standard for DDR2 RAM is 1.8V. You motherboard has both and AUTO and manual setting capability for memory (DRAM) voltage. It is possible that the AUTOP feature is not detecting the need for 2.2V, and that with only one DIMM installled, the memory marginally functions, but with the extra loading of the second it will not. Boot the system with the single DIMM, go to the BIOS, and set the DRAM voltage manually to the 2.01V setting (Verify by the part number of the RAM with the CRUCIAL website that is uses 2.2V before doing this). Once you have changed the voltage in BIOS, shut down and add the second DIMM and see if things improve.
Jan 16, 2012 | Asrock G31M-S Motherboard
Card reader, nine in one, USB2.0, not connected. Can NOT see place to connect. Mobo is DG965RY, but do not have manual, as it is replacment board from Velocity Micro, for DG965MQ. Can you tell me where to...
Here is the Intel page that has all kinds of links for this board:
DG965RY Support
Look for the on ethat says Board Component Diagram.
Thanks for using Fixya.
PS. You might want to save that page to your favorites.
Also keep in mind if you go to the Intel home page, there is a link that will detect and update all your drivers automatically.
Mar 12, 2011 | Intel DG965RY Motherboard
I brought my intel pc on 23/07/2007, core2 duo processor& dg965ry chipset mother board. Now my system get restarted in every hour, retailer advise me to replace the motherboard, i wish to know whether...
I brought my intel pc on 03/09/2007, core2 duo processor& dg965ry chipset mother board. Now my system get is not booting and showing some EB Display on the right end corner. plz find me the Solution...
Jan 04, 2011 | Intel DG965RY Motherboard
IBM instructions for installing memory modules is that they must be done sequentially starting at DIMM 1. When removing them to upgrade should I then remove DIMM 2 first, and then remove DIMM 1, and...
It shouldn't matter what order you remove and replace the RAM cards in. The instructions are saying to populate Slot 1, Slot 2, and then other slots in order; don't skip any slots, in other words.
Dec 31, 2010 | IBM NetVista Intel Pentium 3 1GHz / 256MB...
Fail to boot
When you say boot do you mean POST?
Is it turning on at all?
What happens exactly when you press the power button?
Any beeps?
Open the case and remove everything except 1 RAM chip, the cpu, the cpu cooler. Hook up the monitor to the onboard graphics and try to boot again.
If it POSTs then you know that you have a problem with one of the pieces of hardware you removed, replace them 1 at a time until it fails to POST then you know which piece is defective.
If it still doesn't POST with everything removed, try a different RAM chip, if it still fails POST then you need to replace the motherboard.
Sep 16, 2009 | Intel DG965RY Motherboard
Intel DG965RY CPU Overheating
Check the clamp of the cooling fan. If the clamp is not engaged, heat sink didn't take the heat away from the micro processor causing CPU over heating.
Jul 03, 2009 | Intel DG965RY Motherboard
DG965RY board can not reboot with 'restart' button on windows Xp
Run with only two RAMS each in one of the DIMM slots. Three RAMS may not work unless supported by mobo or being exactly identical in their specs..
Nov 17, 2008 | Intel DG965RY Motherboard
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
Intel DG965RY Motherboard Logo
216 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
