Question about Aiwa NSX-D77 CD Shelf System
Repair i have this book shelf system that was givin to me from a friend. when i turn it on i notice there where no sound. then i crank up the volume but the sound seems low. so i tested the speaker on another system and it my question to you is could it be the amp is damage. also i pluged in my headphones it it does the same thing.
0 characters
1 Points
The fan only kicks in when a threshold current is drawn by the system. under normal operation it is not turning. Crank up the volume and you'll notice the fan fires. You wouldn't notice this since the system is so friggin loud!!
Jan 26, 2011 | Sony MHC-NX3AV Shelf System
Sound volume knob does't respond
Chances are that it's a digital volume control.
The fact that it turns down again means it's probably fixable.
Open it up (switch it off first), and fetch a soldering iron. Look around for wires that go from the volume control and see if any are loose connections/broken wires etc etc. Solder these again, and it should work.
If you don't fancy this, take it to a hifi shop and they'll fix it for you (there'll probably be a fee involved)
Jan 13, 2010 | Teac DCD2831 Mini Hi Fi System w/3 Speed...
Have you unplugged it from wall since ?
and, do you know if maybe the speakers are blown?
Bad speakers will make it stay in "protect"
Try other speakers after the unplug-plug back in routine.
Try the Denon website for a manual
Jan 11, 2009 | Denon D-M50S CD Shelf System
SA-AK95 volume control problem
This volume controls is actually what is called an encoder. The control itself needs to be replaced. Figure on $5-$10 for the part plus the local labor rate for the total repair cost.
May 01, 2008 | Panasonic SC-AK75 Shelf System
One of the speakers are in bad conditions check it
Mar 30, 2008 | Panasonic SC-AK330 Shelf System
Did you ever find a solution about the startup volume @ 12?
Oct 24, 2007 | Philips MCM298/37 Shelf System
Sound setting
There are several complaints in FIXYA and they are all about this same fault conndition....the volume is too high when turned on...
Because of the high number of complaints about this same fault I would suggest that its a manufacturer fault.
So the manufacturer should be contacted about it to ask for your money back..
Cheers From YUBEUT..
Sep 06, 2007 | GPX HM3817DT Shelf System
Volume really low
sound mute problem.
are you with electronic knowledge to fix this?
i can help.
Jan 11, 2007 | Sony MHC-G100 Shelf System
hi, ya, someimes the POT i.e the volume controller variable resistor loses its contacts with the carbon strip. tru using some switch cleaning solution( NoN Acidic) to clean the POT,let me know
Dec 07, 2006 | Yamaha GX-70 CD Shelf System
Aiwa NSX-D77 CD Shelf System Logo
Top Aiwa Audio Shelf Systems Experts
Are you an Aiwa Audio Shelf System Expert? Answer questions, earn points and help others
