Question about Canon PIXMA MP780 All-In-One InkJet Printer
CHECK PRINTER I think that my printer ink cartridge is clogged. That is the only think i can come up with. Are there any sollutions to this problem? How would I try to clean it? I have tried to re-install it, but the printer bar won't even move and I see ink at the bottom of the printer. Is the printer ruined by this? Thank you, Joy McGrane
  • 1,031 Answers
If the printhead is clogged
Please try head cleaning.Buy alcohol solution (70% or more). You can find it in any drug store.
* Remove both cartridges from the printer head. Unplug the printer head from the printer body. Pour the alcohol into paper towel layer.
* put the printer head on the top of wet towel with the face of HEAD touching the towel.
* clean the head with the towel and get rid of all the built-up ink on the head.
* Pour the alcohol into the printer head container (ink-receptacle area is where the ink cartridge normally sits, notice a small hole where the ink flow into the printer). Do not touch any electronic parts and let it dry over night.
* Do step 2-5 again if necessary.
* Install the cartridge back to the printer and run several head cleaning maintenance, print nozzle check, make sure to repeat this step until no more dead nozzle shown or
click on start / settings / printers & faxes
right click on the printer icon then left click on printing preferences Then click on maintenance then click on cleaning
hope this helps pls appreciate by rating as fixyaa.thanks and God bless
Posted on Dec 14, 2008
My printer is making the sounds that it is printing but the paper is coming out blank. we have not used the printer before however the ink cartridge looks fine..is there something obvious as to why the...
Hello
Sure the ink in the cartridge is clogged and needs to be cleaned. Follow the steps below
1. Open the cartridge access door on your right side of the printer.
2. Remove the cartridge from printer
3. Take a tissue paper with a little water
4. Wipe the nozzles of the cartridge gently
5. Wipe again with an dry tissue and you will find ink deposit on the dry tissue
6. Install back the cartridge in printer
7. Use cartridge cleaning option in the printer.
You are done.
Jul 21, 2011 | HP Photosmart A516 InkJet Printer
Not recognizing ink cartridge?
1.Check the ink. Printers are picky machines. They are programmed so that they would recognise a particular kind of ink. Thus, when you buy compatible ink cartridges, make sure that these ink are truly ones specifically made for your printer. Otherwise, the ink will not work with your printer.
2.Follow the instructions to the letter. Just like the manufacturers of original printer cartridges, the manufacturers of compatible ink cartridges have instructions on how you should place and install the cartridges in the printer. You should follow these instructions to the letter so you can be sure that they would work.
3.Clean the printer head. It is also possible that the reason why the printer would not recognise the compatible ink cartridges you bought is that the printer head itself is clogged. Such problems can occur, especially when you have not used the printer in a long time. You can clean the clogged printer heads with a cleaning solution made especially for printer heads.
If the cartridge itself is the one that is blocked, you can try soaking the cartridge in warm water first. Afterwards, dry it with a lint-free rag and then install it in your printer.
4.Check the circuitry in your printer. Another possible reason why the printer would not read your compatible ink cartridges is that the printer itself has a problem with the circuitry. You can try topping the cartridge with ink first before reinstalling it into the printer.
If that fails, you should bring your printer to the repair shop. Be warned though: If your printer is under warranty, the warranty will no longer be valid if it is found out that you have used compatible ink cartridges.
Feb 26, 2011 | HP PSC 1510 All-In-One InkJet Printer
I replaced black ink of brother printer but still it won't work the screen says: Ink empty black. Replace Ink
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 11, 2010 | Brother MFC 240C All-In-One InkJet Printer
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
My HP Deskjet D4260 printer has been unused for 2 years. I have been told it would be useless to replace dried cartridges, because the inkjets themselves are probably clogged, and therefore the printer is...
That is absolutely not true. The printer you have uses integrated print head cartridges. This means every time you replace the ink cartridges you are replacing the print heads. Throw out the dried up ink cartridges and buy new ones. Your printer takes the HP 74 black and HP 75 color cartridges. There are XL versions of these cartridges that hold more ink and are a better value.
Dec 19, 2009 | HP Deskjet D4260 Printer
My dell 720 printer has a new ink cartridge, acts
Take the plastic strip off the ink jet cartridge before putting the thing in the printer.  Check the ink jets to see if they are clogged.
Oct 25, 2009 | Dell Inkjet 720 Printer
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
"Printing" fine, but no ink is output.
Same printer model with same problem as previously listed, printer goes through the motions but "no ink on page"!
Feb 04, 2008 | Compaq Inkjet IJ650 Printer
Printer doesn't recognize red cartridge
The ink cartridge is either either clogged or running out of ink. Run the software cleaning utility (almost always accessible from the printer) in order to fix a clog. Replace the ink cartridge if the clog cannot be fixed or if the cartridge is almost empty.
Apr 18, 2007 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
88 people viewed this question
old marine
old marine
