Question about Dell A940 All-In-One InkJet Printer
How do I reset the Dell A940 AIO printer?
When I try to print something off I get a message saying that the computer and printer cannot communicate. I have disconnected/reconnected the usb cable, unplugged power cord etc and nothing works. Is there a way to reset the printer? it is not trying to print i dwn loaded the disk and it still will not print
damanpreet_c
  • 69 Answers
SOURCE: hardware error:0502
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
micromend
  • 748 Answers
SOURCE: my dell V305 printer cant print
When you connect and reconnect your printer do you here a "ding" sound. If not then you're USB ports may not be acting correctly or the USB drivers have been infected. Download and run the following: Dr. Web, Malware Bytes, and Superantispyware. Once these are run then go to Start, Run and type SFC /scannow. Be prepared to insert your operating system disk. This should bring the USB drivers back online, then when you plugin your printer your should here a "ding" sound. If the printer still does not communicate then insure that the drivers have loaded. Goto Start, Control Panel, Printers and Faxes. Is your printer there? If it is then the communication problem is on the printer side. If the printer is not listed then select Install printer.
Posted on Apr 04, 2009
  • 85 Answers
SOURCE: Dell Color Printer 725 - Communication Not Available
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
Posted on Jul 29, 2009
john_yap
  • 51 Answers
SOURCE: printer aio 926 communication error
hi aweintra,
you can do the following steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just send me an update if the issue won't be fixed. have a great day.
Posted on Oct 19, 2009
computerdeb
  • 323 Answers
SOURCE: dell a940 AIO makes noise as soon as i turn it on
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Posted on Oct 25, 2009
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Dell AIO A940 is giving me an error code 0502 and won't print. Says it is busy?
    Check this out for the error. The trick here is to make sure the bar is cleaned and lubricated with furniture polish or cooking oil.
    http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
    May 24, 2010 | Dell A940 All-In-One InkJet Printer
    Error 1203 for Dell Printer AIO 926
    Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
    1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
    or
    2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
    Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
    I'm trying g to connect my Dell AIO 922 printer to
    You need to go to Control Panel add/remove programs and remove all Printer programs. Then disconnect the USB cable, install the printer software until a message comes up that says plug in your printer. If no message comes up, complete the software installation and then plug in the USB cable. The computer should find the printer at this time.
    Aug 15, 2009 | Epson Stylus Photo R200 InkJet Printer
    Dell Photo AIO Printer 924 - Printer Busy
    Might need a new printer. Lexmark printers can be troublesome.
    Jul 14, 2009 | Dell 924 All-in-One InkJet Printer
    Install dell old a940 printer on new acer aspire 5920 notebook with windows vista
    I have the same problem but with an acer 5570Z. It used to work with the dell all-in-one, however, one day it just stopped working. It always says it cannot communicate with the printer. I've tried uninstalling it, and reinstalling it several times---no luck.
    Aug 24, 2008 | Dell A940 All-In-One InkJet Printer
    When trying to print it says "Communication Not Available"
    Reinstall the printer driver.
    Get the latest driver from Dell.com Drivers and download.
    Jul 08, 2008 | Dell A940 All-In-One InkJet Printer
    Dell all in one printer 940
    try holding the power down for 15 seconds
    Mar 06, 2008 | Dell A940 All-In-One InkJet Printer
    Dell A940 smeared printing
    Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
    PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
    Maybe it will work for you! Good luck!
    Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
    Dell A940 All-In-One InkJet Printer Logo
    382 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
