SOURCE: airbag light stays on in
You need to access the Airbag ECU (Electronic Control Module) using suitable diagnostic equipment connected to the data link connector of the car in order to erase all faults - DTC (Diagnostic Trouble Codes) memored, unlock and reset the Airbag ECU. Then the Airbag light will turn OFF after approx. 4 seconds, ignition ON.
Good Luck!
1st when the
airbag light is on the system is disabled, so if u have an accident
they will not work, as to the common cause read below.
When
the airbag light is on it means a fault has occurred in the system
and the airbag diagnostic monitor has disabled the system, the most
common problem that turns the light on is a break in the connection
to the steering wheel mounted airbag, this is due to a rotating
ribbon contact that breaks under the steering wheel that connects the
airbag to the wiring harness and the diagnostic monitor, the part is
called th clock spring contact, a coiled up ribbon electrical contact
that turns with the wheel
