Question about DeVilbiss Pulmo Aide Compressor Nebulizer
Humidifer not working
Sharper Image personal humidifer is not producing steam
  • 74 Answers
If the machine actually turns on and you can hear it working your filter is probably plugged. The filter is usually a white cotton plug looking thing located somewhere near the tubing port. Locate the filter it will pull straight out or screw out. You should have a replacement filter in the box the machine came in or should be able to order extras from the company
Posted on Dec 23, 2008
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
Sharper image humidifer ev-hd10
follow this steps and fix it. God bless you
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Nov 28, 2013 | Irons
How do i make the Sharper Image SA251 Subwoofer Speaker work what do i use as a line level?
I don't suppose they came with a manual.
http://www.spreadmyad.com/san-diego/merchandise/electronics/8242133-sharper-image-subwoofer-san-diego-25
Line level would (usually) be the LFE signal produced by a multichannel receiver. The speaker level inputs would be from the Front L and R speaker outputs.
Aug 04, 2011 | Sharper Image SA251 Subwoofer
Does not put out steam; makes a clicking sound but does nothing.
ru waiting 1 to 2 mins after turning switch to steam. because u must wait for it to create steam..just on start-up
Jul 30, 2010 | Sharper Image SI570 Steam Wizard Handheld...
Owners manual and operating instructions
I need the users manual for a sharper image turbo sm240 handheld steam cleaner that I can print off the computer. thank you
Dec 21, 2009 | Sharper Image SI785 Clock Radio
My Sharper Image Ionic Breeze, model 51737worked fine but when I turned it on today it wouldn't work. What could the probelm be?
those things are not worth a bit. you should throw it away you could even possibly be causing yourself more indoor air quality problems by running one with the amount of ozone they produce and put into your home. throw it in the garbage.
Sep 12, 2009 | Sharper Image Air Purifiers
DeVilbiss Pulmo Aide Compressor Nebulizer Logo
372 people viewed this question
Top DeVilbiss Health & Beauty Experts
syspro
Tom Chichester
Are you a DeVilbiss Health and Beauty Expert? Answer questions, earn points and help others
