Question about Samsung Digimax S730 Digital Camera
It will not take any pictures
I click the button to take a picture & it is like it almost freezes. After about 15sec. it goes back to normal & it didnt take a picture.
  • Anonymous Dec 15, 2008
    i have the same problem with mine, please let me know if you find a solution
  • softball7792 Dec 25, 2008
    i found out it is the flash. probably better if u just get a new camera.
    Problem Solver:
  • 7 Answers
You can try reformatting the camera, that fixed some problems with mine.
Posted on Dec 21, 2008
My pl170 keep freezing after taking a few pictures
Lens jammed issue. little twist the lens in anti clock side and then try again in normal use.
Aug 05, 2012 | Samsung DualView PL170 Digital Camera
Picture gets fuzzy then screen goes black-still has sound
It can be the T-CON board is over heated and goes out, it can also be the main board, you should try cooling the T-CON board when the picture gose out with electronic freeze spray for electronics troubleshooting to see if the picture will come back, need to narrow down the problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 18, 2010 | Akai LCT42Z6TA 42 in. LCD Television
I have a hitachi tv model # 51f59, the picture and sound are fine, my problem is that in the upper right corner the PIP is on, no matter what i do I can not get it to go off, I have hit the PIP button...
hello Press the PAUSE button to freeze the picture you
are currently viewing (only the right sub-picture will
freeze). Press the EXIT button to return to normal
viewing. Please refer to page 27 for detailed spec. if this don't work i'll send you the manual for free get back to me i'll send you my email address thanks
shaun
Oct 25, 2009 | Hitachi 51F59 51" HDTV Projection...
Sony lcd tv picture freezes
I saw the solution posted to your problem talking about the picture freeze feature on Sony TVs. I presume you're not touching a button on the remote when your picture is doing this.
Normally when a picture freezes it isn't the TV but the signal the TV is receiving from whatever source it's hooked up to. If you have digital cable and the company is having any type of technical difficulties with their signal, it can cause the picture to freeze. If you've ever watched TV with someone who has Dish or DirecTV while a storm was over-head, you may have seen it happen to their picture. However, if you're able to rule out the cable equipment and the cable company as being the problem, then there is something wrong with your TV. If your TV has this picture freeze feature the other guy was talking about, it's possible the feature is now malfunctioning . Whatever the case, if it's the TV the only troubleshooting you can try is to unplug the unit for 30 minutes. If that doesn't fix the issue, the TV likely needs to be serviced. Follow the link below and it will take you to Sony's esupport page. There you will find a phone number you can call, or you can chat with someone online regarding your particular issue. Good Luck!
I hope I've provided you useful assistance and that this informationallows you to make an informed decision as to how to proceed fromhere. Please be sure to vote on my response. I hope I've earned agood rating from you today.
Please post a comment if you needadditional assistance so that I can help you further.
Aug 04, 2009 | Televison & Video
My samsung dlp has no picture or sound. Model hls5066wx, power comes on lamp light flashes for 15sec and then the standby lamp comes on then it goes back to the lamp light flashing. It repeats this a few...
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 12, 2009 | Samsung HL-67A510 67" DLP HDTV
Picture fluctuates
your location area may be theres a big machines interfering your AC line. as you've noticed it runs normal intermittently. i suggest to use a AC condenser or a AVR for this might solved your problem. good luck.
Aug 24, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Remote is not working
I have the same thing. NOTE THE TROUBLE IS NOT IN THE REMOTE IN THIS CASE. It is in the control ciruits OR the power supply ciruits which operate the control circuits. [I think}. My set is "stuck" on chan. 10, I get a great picture, the volume is "stuck" where it was when the trouble occurred; I was changing the channel with the +/- controls on the remote when the trouble occured- I am not sure if I heard a sound from the set when it stopped responding or not. Now, there is no response in the set to the buttons on the set or the buttons in the remote- OTHER THAN ON/OFF. -and re. the on/off- when I shut the set off with the remote- th picture goes dark as it should pretty immediately- but there is about a 15sec delay before the sound shuts off [and the pilot light on the set goes red at that point also] I have opened the back of the set [I bought the set from a crook on ebay, it had been opened, past warranty anyway] and I MUST ADMIT I AM VERY IMPRESSED WITH THE QUALITY/CRAFTSMANSHIP I FOUND THERE. THE THING IS RATHER BEAUTIFULY/STURDILY MADE!! dOES ANYONE HAVE A SCHEMATIC FOR THIS SET OR KNOW OF ONE THAT HAS BEEN FIXTD?? DAVIDO ideals@cox.net
Mar 31, 2007 | iLO 2600 Television
Samsung Digimax S730 Digital Camera Logo
60 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
