Whilpool washer model LA9100XTNO seems to have the tub "come loose" and just flloats around and bangs in the box. hubby is trying to fix it. help!
  • Anonymous Apr 13, 2009
    tub suddenly began making horrible sound in spin cycle. Tub is loose and slamming against lid and sides.
  • 1073 Answers
SOURCE: Kenmore F/L Washer Model 41743142200 tub loose
you may have a dampening shock that is bad
Posted on May 08, 2008
SOURCE: maytag washer bangs during spin cycle
My maytag washer wont spin the water out during it's final spin on the heavy cycle, but if I move the button to another cycle like delicate or medium it will spin out the water during that final spin. there is no hose blockage, the water does pump out during another setting just not on the long heavy cycle. Model lat8714ae........ao17894ko...any ideas anyone????
Posted on May 16, 2008
milten1
  • 1304 Answers
SOURCE: washer makes loud clunk as it goes around.
it sounds like you have a broken spinner assembly,
this is the unit that connects your innur tub to you center shaft seal,,,,
it can be replaced and repaired by you no special tools but the cost could be quite extensive....
an outer tub and spinner is an absolute minimum and there are parts to inspect as you take it apart
do you need both halves of the outer tub would be the biggest one
unless this machine is less than just a few years I would just not bother putting the money into it
its well past cost effective 500.00 for the two parts ive mentioned
Posted on Nov 02, 2009
SOURCE: WCVH6800J1WW GE Washer error codes
need same solution, please post
Posted on Jul 30, 2010
  • 1531 Answers
SOURCE: The washer made a horrible noise and the tub seems
you need to remove the agitator and check the bolts that hold the trunion to the shaft and make sure they are not broken.if one is just replace them make sure that the bracket is in the flat key way on the tub hope fully the tub seal is still good.
Posted on Oct 16, 2010
Testimonial: "Sounds like I need to call a repairmen. Thank you so much."
I have a Kenmore washing machine model # 11020854990 which recently had a loud banging and knocking sounds during the final spin cycle. Now I notice the drum seems to have dropped down about an inch plus...
Could be a loose basket nut, or on the bottom tub support there are a few springs that help locate the tub. One of the springs could have come off or broke.
Nov 28, 2017 | Kenmore 24032\24036 Top Load Washer
The washer made a horrible noise and the tub seems to be loose from the machine. Can I fix it? The tub in my Frigidaire stacked washer all of a sudden with a fairly heavy load of jeans started making a...
Oct 15, 2010 | Frigidaire FEX831CS Top Load Stacked...
The drum is loose in our washing machine. It bangs around during spin cycle. Is this something I can fix myself, or do I need a replacement?
the collar under the tub has down thats why the tub is acting that way,if you have a spanner wrench you can remove and check-mike
Feb 18, 2010 | Kenmore 22422 Top Load Washer
Loose inner drum
your bearing is gone. needs a new tub assembly. its pricy
Feb 05, 2010 | Frigidaire GLTF1240A Front Load Washer
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Maytag HAV4657EWW tub bangs during spin
This washing machine has self-leveling rear legs. Tilt the machine up on the front legs and you'll hear the back legs drop down to re-level itself. Center the basket and restart.
Mar 10, 2009 | Maytag MAT13MN Top Load Washer
Makes a loud banging sound when spinning clothes
check springs and shock absorber.try to put more laundry.
Feb 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Front Loading Washer - Load Banging During Spin Cycle
hello, your problem is that your shocks are bad and need to be replaced. you can access them by removing the front lower panel. make sure you unplug the washer first. you will see 2 of them on either side of the tub. i belive you can twist the upper portion and then remove the bottom screew and remove the shock. of course before you start you should have the new shocks. and make sure their is no water in the tub.
Dec 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
