Question about LG WM1812C Front Load Washer
Re: lg wm1812
Spits water at the back (front loader)
    Novelist:
  • 116 Answers
There is a vent at the back of the machine near the top that is covered by a small round white plastic cross pattern. Inside of the machine there is a black flexible hose that attaches to the vent from the top of the outer tub. inside of the tub attachment point is supposed to be a light blue plastic valve that looks like an old style army helmet on a peg. The peg fits into a flange in the opening on the outer tub. If this valve is missing water will escape from the vent on the back of the machine. Another likely point of water leak is a loose inlet hose or missing washer on the inlet hose.
Posted on Mar 15, 2007
Hi, I have a LG Tromm WD-14331AD. At the start of the wash cycle, water will dispense, but not a lot. When spinning, there is hardly any water in the drum and water just stops dispensing.
A front loader only uses a very small amt of water. That's the point of front loaders. Make sure u only use a very small amt of detergent also. And use white vinegar in place of fabric softener. If washer is slow to fill you can check the filters in the supply lines. Take the water lines off the back of the washer and check the filters in the washer
Jan 01, 2017 | LG Washing Machines
Lg wm1812 wont drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Jul 09, 2011 | LG WM1814CW Front Load Washer
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
I have an lg wm1814cw front loader with a ue code
Probably the pump filter is blocked.Make sure the machine is empty...Access filter via small door at floor level. Unscrew the filter cap, and clean filter. check that there isn't a coin stopping the impeller vanes. ...When you take the cap off, any water left in machine will flow out!! Leaning the machine back can help.....Good luck...Nomess
May 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG front load washer WM1812 CW will not pump
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation - but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG has some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2010 | LG WM1812C Front Load Washer
Need link for manual for LG washer WM 1812 CW
You could download the manual from ;-
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WM1812CW-_E
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 30, 2009 | LG WM-1832C Front Load Washer
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
My Lg split system air con spits water
Make sure the unit is tilted downward at the back. About 1" lower than the front is good. Even with a drain, the water will pool inside if it doesn't have a slope for drainage.
Feb 19, 2009 | LG LB1200ER Air Conditioner
LG WM1812C Front Load Washer Logo
534 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
