Question about Alesis P3 Power Supply Barrel (694318007099) Power Supply
What is the polarity of a Alesis P3 Power Supply Barrel ?
I need to replace the jackend a s someone trod on it
  • 3 Answers
The P3 is an AC supply; so there isn't the question of polarity. Connect it either way.
Posted on Dec 05, 2010
Does the alesis sr 16 have a back light on the screen
yes, it should light up when you turn it on. Make sure you have the right adaptor. The voltage & polarity will be wreitten on the unit. My adaptor is from Alesis. You can find these on ebay.
Jul 09, 2014 | Alesis Sr 16 Stereo Drum Machine
Tip
How to use a P3 power supply with a P4 or newer motherboard.
Well its fairly simple, You need the following cable to convert your P3 power supply into P4 power supply.
The pictures pretty much explain every thing, this is the only plug that is not present on a P3 power supply. You can make this cable your self by salvaging connectors from non-working power supplies and other computer peripherals. The connections are straight forward just connect both the yellow wires to the single yellow wire and the black wires to the black wires and your done.
on Feb 09, 2010 | Computers & Internet
Connected alesis sr16 with alesis 110v power supply.to 240v mains...........briefly powered up and then nothing. Have I "fried" the adapter or the sr16?
Look carefully at the adaptor and see if it takes any voltage besides 110 (it will say in very tiny print, you will need a magnifying glass). if it does NOT say 220V or 240V then you friend the adaptor. Get another adaptor - most are "dual" voltage meaning they run in the U.S. or overseas.
Also check for "polarity" (which part of your plug is + or - ).
Jan 24, 2013 | Alesis Sr 16 Stereo Drum Machine
Polarity of the 12v supply ?
Positive is inside the barrel, negative is on the outside of the barrel.
http://s807.photobucket.com/home/budm/allalbums
Mar 31, 2010 | Star Logic 17" LCD Monitor
What voltage power supply do need for the momo force feedback wheel i go one second hand and it was missing the power supply please could help?
Hi, Here all the specs of the Power adapter you looking for. Thanks and have a nice day ! J -
- Adapter model: ADP-18LB C
- Adapter Input: 200-240 V / 50-60 Hz ~ 400 mA
-Adapter output: 24.0 V - 0.75 A Output Plug - Outside Diameter (mm): 5.50
- Output Plug - Inside Diameter (mm) : 2.10
-Output Plug - Barrel Lenght (mm) : 12.00
- Output Plug - Polarity : Center positive.
thanks and have a nice day J -
Mar 30, 2010 | Logitech Momo Force Racing Wheel PC
External power problem
It's actually the opposite. 1/8" jacks are almost always positive tip. I think you are best off using a 9VDC supply. If the voltage is not staying constant at 9 volts it could certainly do damage. If the supply you used was a negative tip positive sleeve you may have burned out a component or two...and more voltage than recommended could have done some other bad things. If it does not work with a 9VDC supply with the correct polarity you can fix it yourself if you have electronic experience. You could also send it to me and I'll fix it at a reasonable rate.
Aug 26, 2009 | Ibanez Ts808 Vintage Tube Screamer Reissue
HD24 won't mount drive in Bay 2
Alesis published a patch for the HD24 which involves adding a 2200uF capacitor to the HD24, which solves this problem for some drives that never mounted before. As electrolytic capacitors age, their capacity reduce- which may cause this problem. It may well be you can fix this problem by replacing the existing 2200uF capacitor with a fresh one, keeping the polarity of the capacitor in mind of course.
Oct 24, 2008 | Alesis ADAT HD24 Fireport (ALADHDFIR)
What is the voltage, current, and polarity of the power supply for the SC-D23?
You should use the original Samsung supply since it is a switching power supply capable of supplying the needed current to operate the onboard charging circuit. Many customers have tried to go with generic supplies and it opens the inline chemical fuse due to the unit drawing heavy current during battery charging. Hope this helps. Joe Weibel Custom Electronics Memphis, TN 38133 (customelectronics.org)
Feb 12, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Computers & Internet Logo
568 people viewed this question
Top Alesis Computers & Internet Experts
John Bolton
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
