Question about Kenmore 24032\24036 Top Load Washer
My Kenmore 80 top loader washer is full of water and will not drain. Yesterday I tried to speed the cycle along and stop it during rinse cycle and moved it forward but now I have tried everything and it will not drain. I have taken all the clothes out and now trying every cycle to see if I can get the water to drain.
  • Anonymous Dec 14, 2008
    Washer full of water, stopped and will not spin or empty
  • Laura Marsh-villalobos Dec 16, 2008
    will agatate but wont spin or drain
  • Kenmore Master
  • 5,568 Answers
Sounds like the drive belt that operates the pump has failed.
You will have to pull the washer out and remove the back panel to peer inside. The pumps are normally a piece of **** plastic and about the diameter of a 'personal pizza' and are driven by a V-belt when working. You should also be able to see that one of its hoses goes to the rear of the machine and exits to the drain pipe.
If you find you do need a belt, you can get the proper part number from the online Sears/Parts section by entering your complete model number when asked.
The pumps don't normally quit instantly but start to leak on the floor if the seals fail so it is likely only the belt.
Posted on Dec 15, 2008
Washing machine keeps draining during rinse
You may be experiencing a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Apr 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Washer won't drain
Dear cbringer,
I have the same washer. I have had the same problem with it. It's the timer module. You can get additional help from http://www.repairclinic.com.
Hope This Helps,
Jay
Mar 12, 2009 | Kenmore Washing Machines
Kenmore Model 24642300
It is usually a coupler, look under to see if black shavings
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
43 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
