Question about Sharp AL 1215 Black and White Copier
MY SHARP AL-1010 IS MAKING A CLICKING SOUND AND THE PAPER JAMS
IT PICKS UP THE PAPER FROM THE TRAY BUT THEN WILL NOT CONTINUE TO BE PRINTED OR COME OUT WHERE IT SHOULD
I HAVE TO OPEN THE BACK OF THE MECHINE AND REMOVE THE PAPER
  • jasej Dec 17, 2008
    I have been told by sharp that the roller has some paper left on it or the roller is not rolling at all i dont know how to remove it to see what is going on with it
    thanks for your help
    President:
  • Sharp Master
  • 990 Answers
Clean up paper delivery roller, if paper come out little bit out and stop, then you have a paper exit sensor damage
Posted on Dec 15, 2008
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
Paper jams does not deliver P light comes on
check to see if a tiny piece of paper is blocking the paper path. also remove paper from the cassette(which pulls out from the front) and try feeding paper from the tray on the right side. Good luck.
Jan 11, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Machine started making a loud clicking sound and wont copy
fuser roller gear is cracked... or a spring holding the bypass is loose
Dec 11, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp AL1642CS makes clicking sound when rollers turning
If you are in the US then go to sharpusa.com business copiers and locate dealers
Nov 21, 2009 | Sharp AL-1642CS Copier
Flashing p and paper will not feed it jams
Clean the paper feed roller under paper tray use izopropilic alcool.
Sep 27, 2009 | Sharp AL 1631 Copier
IN MX-M350N SHOWS "REMOVE PAPER FROM TOP TRAY" AND DOESN'T PRINT
You probably have a paper jam in the auto feed unit. Open the auto feed and check for bunched up paper and if you don't find any open the side doors and check for paper jams there. Let me know what you find.
Feb 13, 2009 | Sharp AL 1631 Copier
Sharp Al-800 Skewed Copies
one problem with this machine, a small pin comes out on the paper release handle in the back, which lets on side of the paper lift tray to come up higher than the other. might look in that area. good luck
May 15, 2008 | Sharp AL 800 Copier
Jams EVERY TIME
Where is the paper jamming? Out of the paper tray or under the drum or in the fixing unit? Did you make sure you have the paper tray set up to the correct paper size and orantation for the paper in the paper tray and dose it happen at any other time and where is it jamed up at. Need more info.
Mar 14, 2008 | Sharp AL 1631 Copier
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
Sharp AL 1215 Black and White Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
