I cannot remember the password to the v-chip on my television and I need to reset it. Can someone please give me advice on how to change the v-chip password?
See above, perfect solution. Only thing, universal remotes won't work to fix the problem. You must have an orion remote controller.
A new remote can be ordered from orion. You should find the customer service # on the back of your set. I ordered a new remote ( for item with ship and handling total cost, $15.00)
(only took 4 days to arrive), and after following the above steps tv is back to snuff!
Thank you guest you helped me fix a tv that i thought just needed to be junked!!!!
This will probably work for most Orion V-Chips... I figured it out looking at another manufacturer's instructions, on my Orion, turn the volume down to 0, change to a blocked channel (where it asks for V-Chip password), then on the TV (not from the remote) hold the volume down button, and hold the '0' key on the remote for between 2-10 seconds... the screen should unlock and you should have no V-Chip restrictions. You can then use your manual to find out how to set the restrictions you want.
Thank you for rating this solution.
Look in the owners manual as sometimes they give you a backdoor way into resetting or changing the password. then you can go in an turn it off.
