Question about Bosch 1/2" Variable Speed Hammerdrill
Broken Forward/Reverse Switch on Bosch Model 1198VSR Hammer Drill
I have a Bosch Model 1198VSR Hammer Drill that needs a new Forward/Reverse (directional control switch). Anybody know where I can find it ?.
  • Anonymous Mar 21, 2014
    Cannot switch from forward to reverse
  • 101 Answers
Yes .. should find it here http://www.toolpartsdirect.com/bosch-tool-parts.html
Hope this is Helpful ! Thanks
Posted on Dec 16, 2008
My black and hammer has no forward, but does operate in reverse
That would be Black and Decker, but what model. Generally forward and reverse are controlled by a switch near the trigger, so you can switch one-handed. You may have to repair or replace that switch, or buy a better drill. While lithium batteries are handy, the plug-in drills last so much longer than batteries, cost less, and often work better.
Jun 01, 2017 | Hammer Drills
Dewalt drill model no dw563l-xw not hammering sounds okay but no power behind hammer stroke
The selector switch (hammer drill/drill) has to be fully set to the hammer drill position for it to work. Also, the bit has to meet some resistance for the hammer effect to be more pronounced. Make sure also that your forward/reverse switch is set to forward.
Best regards, --W/D--
Jan 26, 2011 | Garden
Bosch 1199vsr stopped working while drilling through concrete. The reverse works. Help
your tool should have a rotating reversing switch and the contacts for the forward rotation might be dirty or burnt. I would unplug the tool and remove the screw holding the back handle half on and look to see if anything is burnt or just dirty or bent. If you have an air compressor try blowing thru all areas of the tool. Let me know if this doesn't work you can also go to Boschtools.com and type in your model number on the left hand side after clicking on manuals.
Jun 28, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Drill just stopped? not working
These tear the brushes out. You can not use them for hammering. It is a design problem.
Replace the brushes and use only for straight drilling.
Jun 28, 2009 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
My 24v cordless drill is working ok but the switch on the side of drill for turning hammer on and off is missing. what spare parts do i need to get. would it just be the switch hopefully nothing else fell...
In order to switch from hammer to non hammer on the 13624 there is a ring on the clutch near the chuck. The button on the side is for switching from forward to reverse. The part number you will need is 2601099112. This is something that happens quite often on these drills and you may consider getting two. They are less that 5 dollars each.
Jun 18, 2009 | Bosch 13624 24V Cordless Hammer Drills
Bosch psb 600 drill will not reverse
The red button sits on a lever that changes the polarity of the switch output. If this lever feels loose and you can't feel it engaging anything then you need to split the housing and make sure it is seated properly. If it is, and the lever on the switch is moving fine aswell then you should check all the wires coming out of the switch, and if they are all connected properly you will prob need a new switch.
Oct 18, 2008 | Bosch Drills
Bosch 1/2" Variable Speed Hammerdrill Logo
1,362 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
