Question about Whirlpool LER4634J Electric Dryer
Dryer won't heat yp
My whirlpool dryer is working but is not heating up
model# ler 4634j
  • 3 Answers
You might want to check for power at the outlet,you should have 240 to work properly,but you dryer will run on 120 volts but it will not heat
Posted on Dec 19, 2008
  • Whirlpool Master
  • 8,220 Answers
You are going to need a heater element OR a limit kit. A simple continuity check is all that is needed to confirm the failed part. Remove one wire from each component you check so you do not get a backfeed (false reading). Remember to unplug the machine.
If it turns out the clixons are all good and the heater is fine then the timer will probably be the culprit.
Posted on Dec 15, 2008
DRYER WHIRLPOOL LER 6646 SERNO. MS23065579 IT RUNS BUT NO HEAT OUTPUT TO DRY CLOTHES
I would suggest replacing the heating element these are usually always the culprit and pretty much anybody can replace them.
Check here for parts for you model number, they also have good diagrams.
Hope this helps, thanks.
May 12, 2011 | Dryers
Dryer model LER 3624JQ0 has heat, tumbles clothes, no blocked vent problems (cleaned lint catcher & took off hose in back so could vent directly into the laundry room) but after 4 cycles clothes still...
You have a heating problem so go to the link and you can download a video to see how to test and determine which heating thermostat or component has failed and needs to be replaced.
Dryer Repair
Mar 20, 2011 | Whirlpool Dryers
I have a whirpool dryer Model LER 4634 PQ0. The dryer turns but does not heat. What could the problem be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer ler 7620 kq8 Dryer not heating I replaced the heating element and it is still not heating. what do you think it is?
heatman101
Sep 07, 2010 | Whirlpool LER7646E Dryer
Whirlpool LER 6620 heats, but does not tumble.
if the dryer heats the motor should be good. if it hums its either runing or the hum is a stall noise . if belt is in tact then if motor were going so would the drum . so i think the motor isn't going just humming and the heat sw in the motor is stuck closed with lint and you need to replace the motor .. take the belt off and turn motor if it turns free . the blow it out good and reinstall belt and try again ..mm
Dec 03, 2009 | Dryers
Dryer will run but does not heat up
Either bad heating element or missing one leg of the 240V circuit. The motor runs on 120V.
Sep 24, 2009 | Whirlpool LER4600 Electric Dryer
Electric dryer has not heat model # ler 4600
Normally caused by bad thermostats and or heating element
Sep 24, 2009 | Whirlpool Dryers
Whirlpool LER4634J Electric Dryer Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
